Save and Replace component and subcomponent
mat_hijs
Message 1 of 10
mat_hijs
I have an assembly which consists of a standard part, which is the profile, and a bunch of content center parts that are mounted on the profile. I made a configurable master of this and have to place and configure hundreds of them in multiple top level assemblies.
The name of the subassembly is 140 ST 001, 140 ST 002, 140 ST 003, ... and the name of the profile part is 140 SP 001, 140 SP 002, 140 SP 003, ...
The last 3 digits are always the same in the part as in the subassembly, everything before that is fixed.
Right now, I place the master subassembly in the top level assembly, save and replace the master subassembly, and then save and replace the profile part in the subassembly. This works, but I have to do this hundreds of times and would like to be able to do this in one step.
The subassemblies and profile parts are all saved in the same folder.
I would like to create a macro that lets me save and replace the subassembly just like I do now, but then the profile part should be saved and replaced (with the corresponding name) automatically.
How should I go about this?
Replies (9)
Message 2 of 10
yan.gauthier
What you aim to do is to create a copy of both the assembly and subcomponent ?
Are you familiar with VBA ? I might have some sample code, but you will need to adapt it to your project
Message 3 of 10
mat_hijs
That woukd depend on the complexity, I have made some macro's to automatically constrain components and stuff like that. If you could send me the sample code I can check it out and see if I can adapt it, but at least I'll have a base to start with.
Message 4 of 10
yan.gauthier
I went through my code that those this and it. In my case, I create a copy of an assembly with all of its components to a folder.
We use it to import standard components, like a Festo Actuator, and rename all the files so it doesn't cause issues when uploading to the Vault.
Private Sub BrowserNameUpdate(oComponent As ComponentOccurrence, oBrowserPane As BrowserPane)
Dim oNodeDefinition As BrowserNodeDefinition
Dim Occurrence As String
Dim ComponentName As String
Dim oNode As BrowserNode
Dim ComponentFileName As String
Dim NodeName As String
Dim fso As Object
Dim OccurrenceDict As Object
Dim count As Integer: count = 0
Dim oOccurrences As ComponentOccurrences
Dim oSubOccurrence As ComponentOccurrence
Dim oSubOccurrences As ComponentOccurrencesEnumerator
Dim DocName As String
Dim oComponentOccurrenceToRename As ComponentOccurrence
Dim oOccurrenceProxy As ComponentOccurrenceProxy
Dim i As Integer
Dim pos As Integer
Dim randomNumber As Long
On Error GoTo BrowserNameUpdateErr
Set OccurrenceDict = CreateObject("Scripting.Dictionary")
Set fso = CreateObject("Scripting.FileSystemObject")
 'Loop through each component in the three view
For Each oSubOccurrence In oComponent.SubOccurrences
    'Skip welds if in a weldment
    If Not TypeOf oSubOccurrence.Definition Is WeldsComponentDefinition Then
        Set oNode = oBrowserPane.GetBrowserNodeFromObject(oSubOccurrence)
        Set oNodeDefinition = oNode.BrowserNodeDefinition
        ComponentFileName = fso.getbasename(oSubOccurrence.Definition.Document.Fullfilename)
        'Get node name without occurence
        If InStr(1, oNodeDefinition.Label, ":") > 0 Then
            NodeName = Left(oNodeDefinition.Label, InStrRev(oNodeDefinition.Label, ":") - 1)
        Else
            'Set nodename the same as componentFilename to pass over
            NodeName = oNodeDefinition.Label
        'Compare browser label with occurrence name
        If NodeName <> ComponentFileName Then
            Set oSubOccurrences = oComponent.Definition.Occurrences.AllReferencedOccurrences(oSubOccurrence.Definition.Document)
            'Prepare random number between 100000 and 1000
            randomNumber = Int((100000 - 1000 + 1) * Rnd + 1000)
            'Check if occurrences is present more than once
            For i = 1 To oSubOccurrences.count
                'Give a random occurrence value between 100000 and 1000
                pos = 1
                oSubOccurrences(i).name = NodeName & (randomNumber + i)
            Next i
                'Give an ordered value
                pos = 2
                oSubOccurrences(i).name = ComponentFileName & ":" & i
            Next i
            pos = 3
        'Recursively call this sub for sub assembly
        If TypeOf oComponent.Definition.Document Is AssemblyDocument Then
            BrowserNameUpdate oSubOccurrence, oBrowserPane
Next oSubOccurrence
BrowserNameUpdateErr:
If Err Then
    MsgBox "Unexpected Error: " & Err.Description, vbMsgBoxSetForeground, "BrowserNameUpdate"
    Err.Clear
End Sub
Sub BrowserNodeUpdate()
Dim invapp As Inventor.Application
Dim odoc As Document
Dim oAssemblyDoc As AssemblyDocument
Dim oPartDoc As PartDocument
Dim oComponentOccurrence As ComponentOccurrence
Dim sOccurrence As String
Dim oOccurrences As ComponentOccurrencesEnumerator
Dim oBrowserPane As BrowserPane
Dim fso As Object
Dim i As Integer
On Error GoTo BrowserNodeUpdateErr
Set invapp = ThisApplication
Set odoc = invapp.ActiveDocument
'Get to the Model Browser tree view on the active assembly
If TypeOf odoc Is AssemblyDocument Then
    Set oAssemblyDoc = odoc
    Set oBrowserPane = oAssemblyDoc.BrowserPanes.item("Model")
    For Each oComponentOccurrence In oAssemblyDoc.ComponentDefinition.Occurrences
       If Not TypeOf oComponentOccurrence.Definition Is WeldsComponentDefinition Then
            Set oNode = oBrowserPane.GetBrowserNodeFromObject(oComponentOccurrence)
            ComponentFileName = fso.getbasename(oComponentOccurrence.Definition.Document.Fullfilename)
            Else
                Set oOccurrences = oAssemblyDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oComponentOccurrence.Definition.Document)
                For i = 1 To oOccurrences.count
                    'Give a random occurrence value between 10000 and 1000
                    oOccurrences(i).name = NodeName & Int((10000 - 1000 + 1) * Rnd + 1000)
                Next i
                    oOccurrences(i).name = ComponentFileName & ":" & i
                Next i
            If TypeOf oComponentOccurrence.Definition.Document Is AssemblyDocument Then
                BrowserNameUpdate oComponentOccurrence, oBrowserPane
    Next oComponentOccurrence
    oBrowserPane.Refresh
    oBrowserPane.Update
    'BrowserNameUpdate oAssemblyDoc.BrowserPanes.item("Model").TopNode, False
BrowserNodeUpdateErr:
If Err Then
    MsgBox "Unexpected Error: " & Err.Description, vbMsgBoxSetForeground, "BrowserNodeUpdate"
    Err.Clear
End Sub
Sub StandardAssembly()
Dim refDoc As Document
Dim savePath As String
Dim partDoc As PartDocument
Dim progBar As ProgressBar
Dim regex As Object
Dim ComposantesPath As String
Dim myDir As Object
Dim myPath As String
Dim Manufacturer As String
Dim fso As Object
Dim myFilePath As String
Dim myNewFolder As String
Dim matches As Object
Dim potentialManufacturer As String
Dim fileExtension As String
Dim FileDesc As FileDescriptor
Dim newFullFileName As String
Dim DocDescriptor As DocumentDescriptor
Dim FiletoCopyCount As Integer: FiletoCopyCount = 0
Dim IdentifiedManufacturer As String
Dim ProposedName As String
Set regex = CreateObject("vbscript.RegExp")
regex.Pattern = "[^_]*" 'Search groups of digits
'[^     begin exclude group
'_      match this character
']      end of exclude group
'*      match exeption any number of times
regex.Global = False 'end after first match
Set odoc = invapp.ActiveEditDocument
' Set up composantes directory
ComposantesPath = invapp.FileLocations.Workspace & "\Composantes\"
myPath = ComposantesPath
'Flatten All
    'Check Assembly is not saved in project directory
    If InStr(1, odoc.Fullfilename, invapp.FileLocations.Workspace) Then 'first check is to allow assembly from outside project directory e.g.: download folder.
        If Not (InStr(1, odoc.Fullfilename, invapp.FileLocations.Workspace & "\Composantes\", vbTextCompare) > 0 Or _
                InStr(1, odoc.Fullfilename, invapp.FileLocations.Workspace & "\Pièces Client\", vbTextCompare) > 0) Then
            MsgBox "the Assembly contains: " & fso.getbasename(odoc.Fullfilename) & " which is in the project folder. this macro will not be executed", vbExclamation + vbMsgBoxSetForeground, "StandardAssembly"
            Exit Sub
    'Check no files are project files e.g.: 12887_07-100-000-A
    For Each refDoc In odoc.AllReferencedDocuments
        If InStr(1, refDoc.Fullfilename, invapp.FileLocations.Workspace) Then
            If Not (InStr(1, refDoc.Fullfilename, invapp.FileLocations.Workspace & "\Composantes\", vbTextCompare) > 0 Or _
                    InStr(1, refDoc.Fullfilename, invapp.FileLocations.Workspace & "\Pièces Client\", vbTextCompare) > 0) Then
                MsgBox "the Assembly contains: " & fso.getbasename(refDoc.Fullfilename) & " which is in the project folder. this macro will not be executed", vbExclamation + vbMsgBoxSetForeground, "StandardAssembly"
                Exit Sub
    Next refDoc
    'lookup potential manufacturer
    Set matches = regex.Execute(odoc.DisplayName)
    If matches.count >= 1 Then
        potentialManufacturer = matches(0)
        'check if there is a folder already there for this manufacturer
        If fso.folderexists(ComposantesPath & potentialManufacturer) Then
            myPath = ComposantesPath & potentialManufacturer & "\"
    'Prompt user for where to save the file
    myFilePath = reuseLib.SaveMyFile("Create a folder where to save assembly", odoc.DisplayName, myPath)
    If myFilePath <> "" Then 'will be empty string if user cancels
        'Check folder was selected from Composantes directory
         If InStr(1, myFilePath, ComposantesPath, vbTextCompare) > 0 Then
            'change regex pattern to take folder from path
            regex.Pattern = ".*\\"
            Set matches = regex.Execute(myFilePath)
                Set myDir = fso.GetFolder(matches(0))
            Else
                MsgBox "folder detection error while using regex pattern .*\\ et le path: " & myFilePath, vbExclamation + vbMsgBoxSetForeground, "Standard Assembly"
                Exit Sub
            'Validate folder is not composantes directory itself
            If StrComp(myDir.Path, fso.GetFolder(ComposantesPath).Path, vbTextCompare) = 0 Then
                MsgBox "the assembly may not be created in the folder: " & myDir.Path & vbCrLf & "a sub-folder must be selected", vbExclamation + vbMsgBoxSetForeground, "Standard Assembly"
                Exit Sub
            'Look for the selected manufacturer
            regex.Pattern = "(?:" & Replace(ComposantesPath, "\", "\\") & ")([^\\]*)"
            Set matches = regex.Execute(myDir.Path)
                IdentifiedManufacturer = UCase(matches(0).submatches(0))
            Else
                MsgBox "manufacturer not identified", vbExclamation + vbMsgBoxSetForeground, "Standard Assembly"
                Exit Sub
            'if folder is empty then assume we place files there. Otherwise, we create a folder based on user input
            If myDir.subfolders.count > 0 Or myDir.Files.count > 0 Or _
                fso.getbasename(myFilePath) <> myDir.name Or _
                StrComp(Left(myDir.name, Len(IdentifiedManufacturer)), IdentifiedManufacturer, vbTextCompare) <> 0 Then
                ' If identified manufacturer is already part of the name, no need to insert it at the beginning of the path
                If StrComp(Left(fso.getbasename(myFilePath), Len(IdentifiedManufacturer)), IdentifiedManufacturer, vbTextCompare) = 0 Then
                    ProposedName = fso.getbasename(myFilePath)
                Else
                    ProposedName = IdentifiedManufacturer & "_" & fso.getbasename(myFilePath)
                myNewFolder = InputBox("Folder name", "Standard Assembly", ProposedName)
                If myNewFolder = "" Then 'user canceled
                    Exit Sub
                If Not myNewFolder = "" And Not fso.folderexists(myDir.Path & "\" & myNewFolder) Then
                    Set myDir = fso.createfolder(myDir.Path & "\" & myNewFolder)
                Else
                    Set myDir = fso.GetFolder(myDir.Path & "\" & myNewFolder)
                    If myDir.subfolders.count > 0 Or myDir.Files.count > 0 Then
                        MsgBox "le dossier: " & myDir.Path & "\" & myNewFolder & " existe déjà", vbExclamation + vbMsgBoxSetForeground, "Standard Assembly"
                        Exit Sub
            'relativePath = Trim(Replace(oFileDialog.filename, ComposantesPath, "", 1, 1, vbTextCompare))
        Else
            MsgBox "Selected folder is not in the component root folder", vbExclamation + vbMsgBoxSetForeground, "Standard Assembly"
            Exit Sub
    Else
        Exit Sub
Else
    MsgBox odoc.DisplayName & " is not an assembly or is already saved", vbExclamation + vbMsgBoxSetForeground, "Standard Assembly"
    Exit Sub
'validate each subdocument is a partdocument
    If Not TypeOf refDoc Is PartDocument And Not TypeOf refDoc Is AssemblyDocument Then
        MsgBox "Assembly contains other files than sub-assemblies and parts", vbExclamation + vbMsgBoxSetForeground, "StandardAssembly"
        Exit Sub
Next refDoc
savePath = myDir.Path & "\"
count = 0
ComponentName = myDir.name
'Update Assembly
If odoc.FileSaveCounter > 0 Then
    odoc.SaveAs savePath & ComponentName & ".iam", False
Else
    odoc.Fullfilename = savePath & ComponentName & ".iam"
odoc.DisplayName = ComponentName
'count how many files already exists
    If refDoc.FileSaveCounter > 0 Then
        FiletoCopyCount = FiletoCopyCount + 1
Next refDoc
If FiletoCopyCount > 0 Then
    Set progBar = invapp.CreateProgressBar(False, FiletoCopyCount, "Copying components ...", False)
'redo reference of all sub components
    If TypeOf refDoc Is PartDocument Then
        fileExtension = ".ipt"
    ElseIf TypeOf refDoc Is AssemblyDocument Then
        fileExtension = ".iam"
    'increment part suffix (e.g.: XXXXX_1, XXXXX_2, etc...)
    count = count + 1
    newFullFileName = savePath & ComponentName & "_" & count & fileExtension
    'if file already exists, make a new one based on the first
        progBar.Message = refDoc.Fullfilename & " --> " & newFullFileName
        'copy file once, reuse then
        If Not fso.fileExists(newFullFileName) Then
            fso.CopyFile refDoc.Fullfilename, newFullFileName, False '.CopyFile(Source, Dest [,Overwrite (True/False)]
        Set DocDescriptor = odoc.ReferencedDocumentDescriptors.item(refDoc.Fullfilename)
        DocDescriptor.ReferencedFileDescriptor.ReplaceReference newFullFileName
        progBar.UpdateProgress
    Else
        'Change file name to desired location
        refDoc.Fullfilename = newFullFileName
    'Change document display name
    refDoc.DisplayName = ComponentName & "_" & count
Next refDoc
If Not progBar Is Nothing Then
    progBar.Close
'update browser
BrowserNodeUpdate
'Set a progress bar so user understands he has to wait
Set progBar = invapp.CreateProgressBar(False, 1, "Sauvegarde en cours", False)
'Save all documents to new location
odoc.Save2 True
progBar.Close
Set myDir = Nothing
StandardAssemblyErr:
If Err Then
    MsgBox "Unexpected error during StandardAssembly routine: " & Err.Description, Title:="Standard Assembly"
    Err.Clear
        progBar.Close
End Sub
Declare PtrSafe Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" ( _
    ByVal hwnd As LongPtr, _
    ByVal lpOperation As String, _
    ByVal lpFile As String, _
    ByVal lpParameters As String, _
    ByVal lpDirectory As String, _
    ByVal nShowCmd As Long) As LongPtr
    ' EX: Call reuseLib.ShellExecute(Application.hwnd, "printto", strPathAndFilename, "my printer name", vbNullString, 0)
'#If VBA7 Then
    Public Declare PtrSafe Function GetSaveFileName Lib "comdlg32.dll" Alias _
            "GetSaveFileNameA" (pOpenfilename As OPENFILENAME) As Long
    Public Type OPENFILENAME
        lStructSize As Long
        hwndOwner As LongPtr
        hInstance As LongPtr
        lpstrFilter As String
        lpstrCustomFilter As String
        nMaxCustFilter As Long
        nFilterIndex As Long
        lpstrFile As String
        nMaxFile As Long
        lpstrFileTitle As String
        nMaxFileTitle As Long
        lpstrInitialDir As String
        lpstrTitle As String
        flags As Long
        nFileOffset As Integer
        nFileExtension As Integer
        lpstrDefExt As String
        lCustData As LongPtr
        lpfnHook As LongPtr
        lpTemplateName As String
    End Type
  Public Enum OFN_FLAGS
  OFN_ALLOWMULTISELECT = &H200
  OFN_CREATEPROMPT = &H2000
  OFN_DONTADDTORECENT = &H2000000
  OFN_ENABLEHOOK = &H20
  OFN_ENABLEINCLUDENOTIFY = &H400000
  OFN_ENABLESIZING = &H800000
  OFN_ENABLETEMPLATE = &H40
  OFN_ENABLETEMPLATEHANDLE = &H80
  OFN_EXPLORER = &H80000
  OFN_EXTENSIONDIFFERENT = &H400
  OFN_FILEMUSTEXIST = &H1000
  OFN_FORCESHOWHIDDEN = &H10000000
  OFN_HIDEREADONLY = &H4
  OFN_LONGNAMES = &H200000
  OFN_NOCHANGEDIR = &H8
  OFN_NODEREFERENCELINKS = &H100000
  OFN_NOLONGNAMES = &H40000
  OFN_NONETWORKBUTTON = &H20000
  OFN_NOREADONLYRETURN = &H8000
  OFN_NOTESTFILECREATE = &H10000
  OFN_NOVALIDATE = &H100
  OFN_OVERWRITEPROMPT = &H2
  OFN_PATHMUSTEXIST = &H800
  OFN_READONLY = &H1
  OFN_SHAREAWARE = &H4000
  OFN_SHOWHELP = &H10
End Enum
Const OFN_DefaultOpenFlags = OFN_EXPLORER + OFN_LONGNAMES + OFN_HIDEREADONLY + _
    OFN_DONTADDTORECENT + OFN_ENABLESIZING + OFN_NOCHANGEDIR + OFN_PATHMUSTEXIST + _
    OFN_FILEMUSTEXIST
Const OFN_DefaultSaveFlags = OFN_EXPLORER + OFN_LONGNAMES + OFN_HIDEREADONLY + _
    OFN_OVERWRITEPROMPT
'// End code GetOpenFileName    //
' modBrowseFolder
' This contains the BrowseFolder function, which displays the standard Windows Browse For Folder
' dialog. It return the complete path of the selected folder or vbNullString if the user cancelled.
' It also contains the function BrowseFolderExplorer which presents the user with a Windows
' Explorer-like interface to pick the folder.
Private Const BIF_RETURNONLYFSDIRS As Long = &H1
Private Const BIF_DONTGOBELOWDOMAIN As Long = &H2
Private Const BIF_RETURNFSANCESTORS As Long = &H8
Private Const BIF_BROWSEFORCOMPUTER As Long = &H1000
Private Const BIF_BROWSEFORPRINTER As Long = &H2000
Private Const BIF_BROWSEINCLUDEFILES As Long = &H4000
Private Const BIF_NEWDIALOGSTYLE As Long = &H40
Private Const BIF_EDITBOX As Long = &H10
    Private Type BROWSEINFO
        hOwner As LongPtr
        pidlRoot As LongPtr
        pszDisplayName As String
        lpszTitle As String
        ulFlags As Long
        lpfn As LongPtr
        lParam As LongPtr
        iImage As Long
    End Type
Private Declare PtrSafe Function SHGetPathFromIDListA Lib "shell32.dll" (ByVal pidl As Long, _
    ByVal pszBuffer As String) As Long
Private Declare PtrSafe Function SHBrowseForFolderA Lib "shell32.dll" (lpBrowseInfo As _
    BROWSEINFO) As Long
Private Const MAX_PATH = 260 ' Windows mandated
Public Function SaveMyFile(strTitle As String, strFileName As String, strPath As String) As String
    Dim OpenFile    As OPENFILENAME
    Dim lReturn     As Long
    Dim boolReturn As Boolean
    Dim buff As String * 256
    buff = strFileName
    OpenFile.lpstrFilter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
    OpenFile.nFilterIndex = 1
    OpenFile.hwndOwner = 0
    OpenFile.lpstrFile = buff 'String(257, 0)
    #If VBA7 Then
        OpenFile.nMaxFile = LenB(OpenFile.lpstrFile) - 1
        OpenFile.lStructSize = LenB(OpenFile)
    #Else
        OpenFile.nMaxFile = Len(OpenFile.lpstrFile) - 1
        OpenFile.lStructSize = Len(OpenFile)
    #End If
    OpenFile.lpstrFileTitle = OpenFile.lpstrFile
    OpenFile.nMaxFileTitle = OpenFile.nMaxFile
    OpenFile.lpstrInitialDir = strPath
    OpenFile.lpstrTitle = strTitle
    OpenFile.flags = 0
    boolReturn = GetSaveFileName(OpenFile)
    If Not boolReturn Then
        SaveMyFile = ""
    Else
        SaveMyFile = Trim(Left(OpenFile.lpstrFile, InStr(1, OpenFile.lpstrFile, vbNullChar) - 1))
End Function
This code force folder to be in a given folder group. you will need to change that part and also the part where I ask the user to select the folder and location
Good luck !
Message 5 of 10
hi,
it is not working
Message 6 of 10
yan.gauthier
This is VBA not iLogic. which part does not work ?
Also this macro needs to be called from an assembly
Message 7 of 10
yan.gauthier
This code comes from several modules of mine. I reassembled the code so it works.
StandardAssembly is the main macro here. You need to change it to works since it is looking for specific folders which are part of my companies structure.
'#If VBA7 Then
        lStructSize As Long
        lpstrFile As String
        nMaxFile As Long
        flags As Long
        lpfnHook As LongPtr
    End Type
  OFN_READONLY = &H1
  OFN_SHOWHELP = &H10
End Enum
    OFN_FILEMUSTEXIST
    OFN_OVERWRITEPROMPT
' modBrowseFolder
        hOwner As LongPtr
        pidlRoot As LongPtr
        lpszTitle As String
        ulFlags As Long
        lpfn As LongPtr
        lParam As LongPtr
        iImage As Long
    End Type
    BROWSEINFO) As Long
Dim fso As Object
Dim i As Integer
Dim pos As Integer
        ComponentFileName = fso.getbasename(oSubOccurrence.Definition.Document.FullFileName)
        Else
                pos = 1
                oSubOccurrences(i).Name = NodeName & (randomNumber + i)
            Next i
                pos = 2
                oSubOccurrences(i).Name = ComponentFileName & ":" & i
            Next i
            pos = 3
Next oSubOccurrence
If Err Then
    Err.Clear
End Sub
Dim fso As Object
Dim i As Integer
    Set oBrowserPane = oAssemblyDoc.BrowserPanes.Item("Model")
            ComponentFileName = fso.getbasename(oComponentOccurrence.Definition.Document.FullFileName)
            Else
                    oOccurrences(i).Name = NodeName & Int((10000 - 1000 + 1) * Rnd + 1000)
                Next i
                    oOccurrences(i).Name = ComponentFileName & ":" & i
                Next i
    oBrowserPane.Update
If Err Then
    Err.Clear
End Sub
Dim regex As Object
Dim myDir As Object
Dim fso As Object
'Flatten All
    If InStr(1, odoc.FullFileName, invapp.FileLocations.Workspace) Then 'first check is to allow assembly from outside project directory e.g.: download folder.
        If Not (InStr(1, odoc.FullFileName, invapp.FileLocations.Workspace & "\Composantes\", vbTextCompare) > 0 Or _
                InStr(1, odoc.FullFileName, invapp.FileLocations.Workspace & "\Pièces Client\", vbTextCompare) > 0) Then
            MsgBox "the Assembly contains: " & fso.getbasename(odoc.FullFileName) & " which is in the project folder. this macro will not be executed", vbExclamation + vbMsgBoxSetForeground, "StandardAssembly"
            Exit Sub
        If InStr(1, refDoc.FullFileName, invapp.FileLocations.Workspace) Then
            If Not (InStr(1, refDoc.FullFileName, invapp.FileLocations.Workspace & "\Composantes\", vbTextCompare) > 0 Or _
                    InStr(1, refDoc.FullFileName, invapp.FileLocations.Workspace & "\Pièces Client\", vbTextCompare) > 0) Then
                MsgBox "the Assembly contains: " & fso.getbasename(refDoc.FullFileName) & " which is in the project folder. this macro will not be executed", vbExclamation + vbMsgBoxSetForeground, "StandardAssembly"
                Exit Sub
    Next refDoc
    myFilePath = SaveMyFile("Create a folder where to save assembly", odoc.DisplayName, myPath)
            Else
                Exit Sub
                Exit Sub
            Else
                Exit Sub
                fso.getbasename(myFilePath) <> myDir.Name Or _
                StrComp(Left(myDir.Name, Len(IdentifiedManufacturer)), IdentifiedManufacturer, vbTextCompare) <> 0 Then
                Else
                    Exit Sub
                Else
                        Exit Sub
        Else
            Exit Sub
    Else
        Exit Sub
Else
    Exit Sub
        Exit Sub
Next refDoc
count = 0
ComponentName = myDir.Name
'Update Assembly
Else
    odoc.FullFileName = savePath & ComponentName & ".iam"
Next refDoc
    count = count + 1
        progBar.Message = refDoc.FullFileName & " --> " & newFullFileName
            fso.CopyFile refDoc.FullFileName, newFullFileName, False '.CopyFile(Source, Dest [,Overwrite (True/False)]
        Set DocDescriptor = odoc.ReferencedDocumentDescriptors.Item(refDoc.FullFileName)
    Else
        refDoc.FullFileName = newFullFileName
Next refDoc
    progBar.Close
'update browser
BrowserNodeUpdate
odoc.Save2 True
progBar.Close
Set myDir = Nothing
If Err Then
    Err.Clear
        progBar.Close
End Sub
    Dim lReturn     As Long
    buff = strFileName
    #If VBA7 Then
    #Else
    #End If
    OpenFile.flags = 0
        SaveMyFile = ""
    Else
End Function
Message 8 of 10
I have a master assembly that contain some library parts & some customized part. I need a iLogic / vb code to open master assemble in other project, then SaveAs its customized part in that project except library component.
Can you please help
Message 9 of 10
yan.gauthier
With that code, you have plenty enough to build something that will do exactly what you need.
Message 10 of 10
hi,
while using these vba code it is showing error "unexpected error :Method 'Name'' of object ' ComponentOccurence' failed"
