Save and check in all open documents
alexander.duell
alexander.duell
I am trying to write an Ilogic code that saves and basically checks in all open documents in Inventor to Vault. Both IPT's, IAM's and drawings. It does not check in all documents, but I can't figure out why...
It looks like this.
Dim app As Inventor.Application = ThisApplication
M1 = MessageBox.Show("Vill du checka in alla öppna filer?", "Vault Check-in", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
If M1 = vbYes Then
		Dim oDoc As Inventor.Document
				For Each oDoc In ThisApplication.Documents.VisibleDocuments
						oDoc.Activate()
						saveCmd = app.CommandManager.ControlDefinitions("AppFileSaveCmd")
						saveCmd.Execute
					MessageBox.Show(oDoc.DisplayName)
					"Line for debuggind purposes"
					MessageBox.Show(ThisApplication.ActiveDocument.Displayname)
						ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2(True)
				Next
				MessageBox.Show("Vault Check-in klar", "Vault Check-in")
	Return
 I cant get it to work as intended.
Will someone please have a look?
Best Regards
Alex
Jacob__with__a__k
not seeing any mistakes at first sight
one difference with my code: I'm using ".execute2(False)" (not that it should matter)
ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2(False)
System.Windows.Forms.SendKeys.SendWait(CommentBox & Chr(9) & vbCrLf)
when I'm using my version of this (on 5 ish open drawings) it sometimes fails on half of the drawings, I too would love a stable solution to this
Currently I'm waiting for our upgrade to inventor 2024 to use the new functions, hopefully those work better 🙂
alexander.duell
Thank you for answering,
That is the problem. I have a set of a coulpe IPT, IAM and IDW's
And it fails on some of teh IDW's, and i cant figure out why. As you, I do look for  stable and proof solution to this.
Best Regards,
Alex
