Save an excel spreadsheet from the Inventor VBA
shastu
Advisor Advisor
shastu
I am trying to save an excel spreadsheet from the Inventor VBA.  What do I have to do to get it to work.  It works from an excel VBA but not when I paste it into my Inventor VBA.  This is my code where sProp is a variable.
ActiveWorkbook.Saveas FileName:="C:\Users\ShaStu\Documents\" & sProp & ".xlsx", _
        FileFormat:=xlOpenXMLWorkbook, CreateBackup:=False
sajith_subramanian
Autodesk Support
Autodesk Support
Hi shastu,
Below is a piece of code from another discussion that does something similar.
Sub CreateExcelDoc()
    Dim AppXls As Excel.Application
    Dim wb As Excel.Workbook
    Dim ws As Excel.WorkSheet
    Set AppXls = CreateObject("Excel.Application")
    Set wb = AppXls.Workbooks.Add
    Set ws = wb.Worksheets.Item(1)
    'Putting dummy values
    ws.Range("A1").Value = "Cell A1"
    ws.Range("A2").Value = "Cell A2"
    ws.Range("A3").Value = "Cell A3"
    wb.SaveAs ("C:\TEMP\TestCreate.xls")
    Call wb.Close
End Sub
Let me know if it helps.
Sajith
Sajith Subramanian
Autodesk Developer Network
shastu
This worked:
excel_app.ActiveWorkbook.Saveas FileName:="C:\Users\ShaStu\Documents\" & sProp & ".xlsx"
