same title block across sheets
Hi, I am trying to get the same title block across multiple sheets in the same drawing. Same details, same pattern.
Can't seem to figure it out. I have the ansembly on the first sheet and each part on a different sheet, I created an auto-fill title block but it only works on the first sheet, I have to manually introduce the data on the other.
Is it possible to have the data transfered on all the other sheets?
Thank you very much!
WCrihfield
Your title block definition's sketch probably contains linked text that attempts to retrieve data or iProperty info from the model document.  In a drawing document, 'the model' it is referring to is always the one being shown in the first drawing view you placed onto the drawing that had a model reference in it.  Any other drawing view you place into the drawing, that may be representing other model documents will not be referenced by the title block's linked text.  You may need to have an alternate title block that looks just like your main one, in which you change those text fields from being linked to model data/iProperties to being Prompted Entry placeholders, so you can edit its values on other sheets as needed.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
