Running Rules in Sequence
harrisons22K9B
harrisons22K9B
I am trying to figure out if I can have a message pop up after a form is okayed.
In the picture, I have a simple form with some Parameters that when the user clicks "Done", I would like the Pop up message on right to appear.
I know Event Triggers exist, but I would like the solution to be code based so the message does not pop up every time a "Model Parameter Change" occurs.
Thanks for the help.  And still new at coding, so Comments really help with understanding what is being said in programming language.
Curtis_Waguespack
Hi @harrisons22K9B
what version of Inventor are you running?
2022? 2023? 2024?
harrisons22K9B
Professional 2022
the version before the .4 update
Curtis_Waguespack
Hi @harrisons22K9B
See the attached example file, but here are the steps as well:
  • Create a rule that shows a message box and then edit your form.
  • Set the form to use None as the Predefined Buttons setting
  • Then locate your rule in the left pane and drag it into your form as shown.
  • Then set the On Click Action to be Close and then Run Rule
I hope this helps.
Curtis
harrisons22K9B
@Curtis_Waguespack
That should work for my simple needs.
Thanks for the quick help!  Enjoy your weekend.
