Running a VBA form to access excel spreadsheet with excel application minimized
MCCJohnPetty
MCCJohnPetty
I have a vba userform that accesses an embedded spreadsheet to drive a multibopy part design.  the issue is I do not want the excel application visible (minimized would suffice).  I am able to get the spreadsheet to not show (See snippet below), but I still get the excel application popping up.(see attached image.
Is there a way that I can get the excel application to "disappear" so that the end user only sees the form and the inventor application?
Thanks in advance
Set eApp = Excel.Application
With eApp
.Application.WindowState = xlMinimized
.Visible = False
.ScreenUpdating = False
End With
MCCJohnPetty
Another question in regards to the vba userform:
Is there a way that I can code in the ability for the ipt to do a local update (or global update)?
I currently have this  "ThisApplication.ActiveDocument.Update" at the bottom of my build code, but it doesn't seem to work as expected.
fullevent
Hello @MCCJohnPetty,
depending on how your code is structured, you may be able to fix this by bringing the Inventor application into the foreground (activate it) at a proper place in the code.. as workaround.
On Update, please try .update2 and .rebuild2
That usually worked for me then.
regards
Aleksandar Krstic
Produkt- und Projektmanager
MCCJohnPetty
Thank you.  I will try it.
