Running a command on T&P Add-in Occurrence in Drawing
A.Acheson
Mentor Mentor
Message 1 of 21
A.Acheson
Is it possible to run a command on specific assembly occurrences in the drawing environment.
Using the add-in Tube and pipe. If you right click on the Run assembly occurrence in the browser you are presented with a command “Include Route Centerlines”
I placed this snippet
(ThisApplication.CommandManager.ControlDefinitions(“CADC:Drawing:CenterlineRecoveryChecked”).Execute)
at the point where the loop found the Occurrence.
Using this method the button is not triggered.
 I am guessing this is the case because the command manager is trying to act on the whole drawing and not on the specific Occurrences.  Is there a method to do this?.
Commands:
Include Route Centerlines - CADC:Drawing:CenterlineRecoveryChecked
Include Route Centerlines - CADC:Drawing:CenterlineRecoveryTriState
Include Route Centerlines - CADC:Drawing:CenterlineRecoveryUnchecked
Resources used.
https://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Any help greatly appreciated.
Regards
Alan
Replies (20)
Message 21 of 21
Seemed like it was the Browser that made my problems my final uptate if any body are interested:
'Error with clicking vs select set
'https://forums.autodesk.com/t5/inventor-customization/what-is-the-difference-between-selectset-select-and-clicking-on/td-p/9249928
Class ShowCenters
	Dim ShowLines As Boolean =True
Sub Main
	'Need to expand the browser to find the tube runs
	ThisApplication.CommandManager.ControlDefinitions.Item("AppBrowserExpandAllCmd").Execute
	Dim que As MsgBoxResult = MsgBox("Show Center Lines",vbYesNo,"Select")
	If que = vbYes Then
		ShowLines=True
		Else
			ShowLines=False
	If Not TypeOf ThisApplication.ActiveDocument Is DrawingDocument Then
		MsgBox("Open a drawing document first")
		Exit Sub
	Dim doc As DrawingDocument
	doc = ThisApplication.ActiveDocument
	doc.SelectSet.Clear
	Dim bp As BrowserPane = doc.BrowserPanes("Model")
    Call GetRouteBrowserNodes(bp.GetBrowserNodeFromObject(doc.ActiveSheet).BrowserNodes) 'only touch active sheet.
    Call GetRunBrowserNodes(bp.GetBrowserNodeFromObject(doc.ActiveSheet).BrowserNodes)
'	'ThisApplication.CommandManager.ControlDefinitions.Item("AppBrowserCollapseAllCmd").Execute2(True)
'	  For Each obj As BrowserNode In tosel
'		Dim n As BrowserNode = obj
'		While n.Parent.Type = obj.Type
'			n = n.Parent
'			n.Expanded = True
'		End While
'		obj.DoPreSelect
'		'Attempt to activate the context menu by RMB ona browser node containing routecenterline. This does not work as may be unsupported.
'		'Imports System.Windows.Forms (Place in Header)
'		'SendKeys.SendWait("+({F10})")'The parentheses indicates that F10 should be pressed while Shift is held down
'		obj.DoSelect 'the command seems to act on the last selected object
' 			'Includes the Route centerline....(opposite to it's name)
'			'oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("CADC:Drawing:CenterlineRecoveryUnchecked")
'		 	'oControlDef.Execute
'			'Excludes the Route centerline....(opposite to it's name)
'        '	oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("CADC:Drawing:CenterlineRecoveryChecked")
'		'	oControlDef.Execute
'		Call ThisApplication.UserInterfaceManager.DoEvents 'lets inventor catch up
'	  Next
		doc.SelectSet.Clear
End Sub
Dim tosel As New ArrayList 'store valid browsernodes
Sub GetRouteBrowserNodes(nodes As BrowserNodesEnumerator)
	'On Error Resume Next
	For Each node As BrowserNode In nodes
		If node.NativeObject IsNot Nothing Then
			'Logger.Info(CType(node.NativeObject.type, ObjectTypeEnum).ToString)
			If (node.NativeObject.type = ObjectTypeEnum.kComponentOccurrenceObject)
								If node.NativeObject.Definition.Document.DocumentInterests.HasInterest("Piping Route Environment")
									tosel.Add(node)
								'Use "Piping Runs Environment" for the top level run defintion
								'Use "Piping Run Environment" for individual runs like Run00, Run01
								'Use "Piping Route Environment"	for individual routes
								If node.FullPath.Contains("Route") Then
									node.DoSelect
									'This needs run before setting the state
									Try
									ThisApplication.CommandManager.ControlDefinitions.Item("CADC:Drawing:CenterlineRecoveryTriState").Execute
								Catch ex As Exception
								Logger.Info(ex.ToString )
								End Try
								If ShowLines Then
						Try
											'If the "Include Route Centerline" is unchecked the code will check it
								ThisApplication.CommandManager.ControlDefinitions.Item("CADC:Drawing:CenterlineRecoveryUnchecked").Execute
								End Try
								Else
									Try
										'If the "Include Route Centerline" is checked the code will uncheck it
								ThisApplication.CommandManager.ControlDefinitions.Item("CADC:Drawing:CenterlineRecoveryChecked").Execute
								End Try
								Logger.Info(node.FullPath)
								'Return 'this run is taken care of so don't search any deeper
					If node.NativeObject IsNot Nothing AndAlso
						(TypeOf node.NativeObject Is DrawingView OrElse
						node.NativeObject.type = ObjectTypeEnum.kComponentOccurrenceObject OrElse
						node.NativeObject.type = ObjectTypeEnum.kAssemblyComponentDefinitionObject) Then
						    GetRouteBrowserNodes(node.BrowserNodes) 'recursively search, only want to search valid node types
	Next
End Sub
Sub GetRunBrowserNodes(nodes As BrowserNodesEnumerator)
			'If (node.NativeObject.type = ObjectTypeEnum.kComponentOccurrenceObject)
								If (node.FullPath.Contains("Run")) 'assuming these are not renamed
									tosel.add(node)
								'Logger.Info(node.FullPath)
						node.NativeObject.type = ObjectTypeEnum.kComponentOccurrenceObject) Then
						    GetRunBrowserNodes(node.BrowserNodes) 'recursively search, only want to search valid node types
		'End If
	Next
End Sub
End Class
Aleksander Myklebust
