Run-time error '13' Type mismatch
austen_27_t
austen_27_t
Can anyone find where this mismatch error is occurring I have been trying to fix it but have not been successful.
Ive attached a picture of the code also showing the error.
Thank you to anyone who can help
Public Sub hex()
'activate the part as a document
Dim pdoc As PartDocument
Set pdoc = ThisApplication.ActiveDocument
Dim pdef As PartComponentDefinition
Set pdef = pdoc.ComponentDefinition
'Establish input dimensions
Dim dim1, dim2
dim1 = InputBox("Enter Hex Size", "HEX")
dim2 = InputBox("Enter Hex Length", "Length")
Dim sides As Long
sides = 6
'create new reference sketch plane
Dim sketch As PlanarSketch
Set sketch = pdef.Sketches.Add(pdef.WorkPlanes.Item(3))
'Sets reference to tg transient geometry
Dim tg As TransientGeometry
Set tg = ThisApplication.TransientGeometry
'Create lines for polygon
Dim hex As SketchLine
Set hex = sketch.SketchLines.AddAsPolygon(sides, tg.CreatePoint2d(0, 0), tg.CreatePoint2d(0, dim1), False)
'Creates a profile.
Dim Pfile As Profile
Set Pfile = sketch.Profiles.AddForSolid
'Create an extrusion.
Dim extrudeDef As ExtrudeDefinition
Set extrudeDef = pdoc.Features.ExtrudeFeatures.CreateExtrudeDefinition(Pfile, kJoinOperation)
Call extrudeDef.SetDistanceExtent(dim2, kNegativeExtentDirection)
Dim extrude As ExtrudeFeature
Set extrude = pdoc.Features.ExtrudeFeatures.Add(extrudeDef)
End Sub
tdant
I think your problem is dim1. The original variable is set as a String, and the CreatePoint2D method takes Doubles as its arguments. Depending on what you're putting in the InputBox for dim1, a possible solution would be to wrap the InputBox in a CDbl(). Does that make sense?
leowarren34
What inventor build is this, and what OS are you using?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
