Run rules if weld environment has been activated
steveh3
Advisor Advisor
steveh3
Gang...still thumbing my way around ilogic. Know enough to be dangereous :-).
So, now I am looking to run a set of rules that the rules only run when the Weldments Environment as been actived.
Eg.
If Welds Enviroment is active, then run these set of rules. Else do nothing.
Possible?
Thanks everyone and stay healthy,
Steve Hilvers
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Darkforce_the_ilogic_guy
can´t you use sub type doc ?  I am not 100 % if weld have it our Subtype but if it have you have use a simple if statment for what you want to do .  You might be ably to se what the Subtype code is for a welding doc ... type is the code is the same for a normale assambly  if not you can use it
MessageBox.Show("Document SubType = " & ThisDoc.Document.SubType)
If ThisDoc.Document.SubType = "{28EC8354-9024-440F-A8A2-0E0E55D635B0}" Then
'Type your code you want to run on only Welding assambly here
steveh3
Thx bt....appreciate the help. It works.
Best,
Steve H.
Steve Hilvers
