Run rule through global form on shown document
jorrytDLRAV
jorrytDLRAV
Hey all,
At my workplace we have created several rules and access these through the Global Forms.
This works almost flawless except for one minor issue.
When someone 'activates' a rule it is done via the pop-up. It will work along the lines like this:
-'click' Part and Assembly (Form with several rules opens)
-'click' create stp-file (rule is activated)
However when you want to create another stp-file from a different part (already opened) you need to close the pop-up. If you don't close the pop-up inventor will create another stp-file from the part the pop-up was activated from.
Is there a way to solve above issue. I tried it with the following code but it does not work.
	Filename = ThisDoc.PathAndFileName(False)
	oDoc = ThisApplication.ActiveDocument
	oDocToModify = ActiveDocument
Thanks in advance!
WCrihfield
Unfortunately, iLogic forms do operate that way.  Whichever document was open visibly and 'active' when the form was launched, that document will remain the focus of that Form until the Form is closed.  Are the target iLogic rules you are running from the global Form's 'local' rules (saved within the document(s)) or external rules?  Which terms you use to identify which document a rule is to target can make a big difference too.  Here is a link to one of my contribution posts that you may find helpful regarding the terms used to identify documents, and what they really point to.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Curtis_Waguespack
Hi @jorrytDLRAV
iLogic works on a document basis, so there's not a real good way to do this.
What I have done though, is to use something like this rule below, to create a parameter/list of all the open visible documents, then set up your form so that you can choose from the list and have your rule run on the selected document.
I hope this helps.
Curtis
Create/Refresh Open Files rule:
Dim oList As New ArrayList
oList.Clear
For Each oDoc In ThisApplication.Documents.VisibleDocuments
	If Not oDoc.DocumentType = _
		DocumentTypeEnum.kDrawingDocumentObject Then
		oList.Add(IO.Path.GetFileName(oDoc.fullfilename))
Next
oList.Sort
'check For Parameter And create If Not found
Try
	oTest = Parameter("OpenFiles")
Catch
	' Get the UserParameters collection
	Dim userParams As UserParameters
	userParams = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters
	oParam = userParams.AddByValue("OpenFiles", oList(0), UnitsTypeEnum.kTextUnits)
End Try
MultiValue.List("OpenFiles") = oList
add something like this to your STEP file rule, other rules you want to run on the selected list item:
Dim oDoc As Document
	oName = IO.Path.GetFileName(oDoc.FullFileName)
	If parameter("OpenFiles") = oName Then
		oDocToProcess = oDoc
		oSTEPname = IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) & ".stp"
		Exit For
Next
If oDocToProcess Is Nothing Then Return 'exit rule if this is nothing
'the rest of your STEP file rule here
'using oDocToProcess & oSTEPname where needed.....
jorrytDLRAV
Thanks for your quick answer!
I already had a feeling that it was just the way Inventor works.
The rules we activate are external rules stored on a server.
Your contribution is very helpful, it adds a bit of clarity to all the different references.
jorrytDLRAV
Thanks! I'l have look and will try to implement it, in to the current workflow.
