Run rule based on file name
josephcooley
josephcooley
I have a rule that reminds people to update the material when they save the file:
materialName = ThisDoc.Document.ComponentDefinition.Material.Name
If materialName = "Generic" Then
	Dim msg = String.Format("Please update material in {0}", ThisDoc.Document.DisplayName)
	MessageBox.Show(msg, "Generic Material")
iLogicVb.UpdateWhenDone = True
 I would like to have this rule not run when it is using tube and pipe and frame generator parts, that dont have a material.  For example when it detects "route", or "skeleton" in the file name.
WCrihfield
Hi @josephcooley.  If you want to do this by checking file name, you can try this:
oDoc = ThisDoc.Document
oFileName = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
If oFileName.Contains("route") Or oFileName.Contains("skeleton") Then Return
materialName = oDoc.ComponentDefinition.Material.Name
	Dim msg = String.Format("Please update material in {0}", oDoc.DisplayName)
oDoc.Update
...Otherwise it is more complicated to tell if a part was generated from tube & pipe add-in.  There is a property of the document called DocumentInterests that I believe will contain a reference to the tube & pipe add-in's ClientId or name, if it was involved.
Wesley Crihfield
(Not an Autodesk Employee)
josephcooley
thanks that worked great!
