Run iLogic rule from an external part file.
meck
meck
I have a solid body part file that holds data for all the parts derived from it. I want to run a rule in one of the derived part files from the solid body part. Is this possible? I did a search for this but couldn't find anything.
Thanks in advance!
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
Curtis_Waguespack
Hi meck,
I think something like this should work for you.
I hope this helps.
Curtis
'''Run ilogic rule in file
'define path and name
Dim sFilePath As String
sFilePath = "C:\TEMP\777.ipt"
'name of ilogic rule
Dim oRuleName As String = "TestRule"
'open the file invisibly
oFile =  ThisApplication.Documents.Open(sFilePath, False)
'define the ilogicAutomation
Dim iLogicAuto As Object
iLogicAuto = iLogicVb.Automation
'get the rule
Dim oRule As Object
oRule = iLogicAuto.GetRule(oFile, oRuleName)
'run the rule
iLogicAuto.RunRuleDirect(oRule)
'close the file
oFile.Close
do you have a code for the File location?
that the file location is always the location of the file that u use?
