Run external rule in all top level subassemblies
mat_hijs
mat_hijs
I've created an external rule "Export to RVT" which exports an assembly to RVT. This works perfectly. All the assemblies I want to eventually export to RVT are placed in one main assembly. So what I would like to do is either write some code which directly exports every top level subassembly to RVT. Or write some code that will run this external rule I have in every top level subassembly. Ideally it would go one step further and filter out subassemblies based on the filename or part number, for example only the ones that start with "V1_". I'm not really sure where to start on this one, but my end goal would be that I run one rule and all the necessary top level subassemblies will be exported to RVT.
Can anyone get me started on this?
The code in my external rule is this:
Dim oAsmDoc As AssemblyDocument
	oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
	oAsmCompDef = oAsmDoc.ComponentDefinition
' Create RevitExportDefinition
Dim oRevitExportDef As RevitExportDefinition
	oRevitExportDef = oAsmCompDef.RevitExports.CreateDefinition
	oRevitExportDef.Location = "C:\Temp"
	oRevitExportDef.FileName = iProperties.Value("Project", "Part Number") & ".rvt"
	oRevitExportDef.ActiveDesignViewRepresentation = "Default"
	oRevitExportDef.IsAssociativeDesignView = True
	oRevitExportDef.Structure = kEachTopLevelComponentStructure
	oRevitExportDef.UseColorOverrideFromSourceComponent = False
	oRevitExportDef.EnableUpdating = False
' Create RevitExport.
Dim oRevitExport As RevitExport
	oRevitExport = oAsmDoc.ComponentDefinition.RevitExports.Add(oRevitExportDef)
theo.bot
@mat_hijs  When you loop thru the Occurenses in a assembly you can call your external rule.
I have a small sample where you loop thru the Occurences and check if the referenced document is an assembly. I also capture the documents names in a list and check if a name already exsist in that list to avoid that you export multiple time the same assembly. I hope this get you started
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
Dim oCompdef As AssemblyComponentDefinition
oCompdef = oDoc.ComponentDefinition
Dim oFiles As New ArrayList
Dim oOcc As ComponentOccurrence
For Each oOcc In oCompdef.Occurrences
	'Get Document Referenced to Occurrence
	Dim oSubDoc As Document
	oSubDoc = oOcc.ReferencedDocumentDescriptor.ReferencedDocument
	If oSubDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		'Check if the file is not already exported
		If oFiles.Contains(oSubDoc.FullFileName) = False Then
		oFiles.Add(oSubDoc.FullFileName)
		Logger.Info("Added to FileList: " & oSubDoc.FullFileName)
			'Additional checks
			'Add rule for Export
		Else
			Logger.Info( "File: " & oSubDoc.FullFileName & " Already exported ")
	Else
			Logger.Info(oOcc.Name & " is no Assembly")
'Run your Rule
Next
mat_hijs
This seems to be exactly what I was looking for, thanks a lot!
