Run an iLogic rule from a form
dleesuk
dleesuk
Hi Folks,
Does anyone know how I can run an iLogic rule from a form without having the rule button on the form.
I have a form which modifies model properties (Title, Checked by Name, Checked by Date, etc.).
However, when this form is displayed I'd like to run a rule automatically which checks the properties being edited belong to a part or an assembly file. I don't wish to change any properties associated with the drawing as the title block is populated from the model properties.
This is my rule:
'check that the active document is a drawing file
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject
    MessageBox.Show("Please run this rule from a PART or ASSEMBLY file.", "iLogic")
    Exit Sub
I can't see a trigger which would do the job.
This seems like a fairly simple thing to do, but I just cant seem to figure it out.
Any clues??
Thank You
Regards
Darren
JoAntt
You can open the form from rule
'Do the things before showing the form
'Then
iLogicForm.Show("MyForm")
dleesuk
I said it'd be easy
Regards
Darren
