run all rule from macro
ac69
ac69
I'm trying to open each ipt file in a folder and run all iLogicRules.
I' m getting the following error: Object variable or With block variable not set.
See code below:
'Get iLogic addins
Dim addIn As ApplicationAddIn
Dim addIns As ApplicationAddIns
Set addIns = ThisApplication.ApplicationAddIns
    For Each addIn In addIns
        If InStr(addIn.DisplayName, "iLogic") > 0 Then
                        addIn.Activate
            Dim iLogicAuto As Object
            Set iLogicAuto = addIn.Automation
    Next
'detect full path to current opened file
File_Name = ThisApplication.ActiveEditObject.ComponentDefinition.Document.FullFileName
myobject.Close
'detect current directory
Directory = Left(File_Name, InStrRev(File_Name, "\") - 1)
'look for all files in the current directory, open, rebuilt and update
Set fs = CreateObject("Scripting.FileSystemObject")
Set f = fs.GetFolder(Directory)
Set fc = f.Files
For Each fl In fc
    If ((InStr(fl, "kelet") <> 0 Or InStr(fl, "param") <> 0) And InStr(fl, ".ipt") <> 0) Then
                Set pDoc = ThisApplication.Documents.Open(fl)
                Set pDoc = ThisApplication.ActiveDocument
                'RunAllRules (pDoc)
                Dim rules As Object
                rules = iLogicAuto.rules(pDoc)
                Stop
                 If Not (rules Is Nothing) Then
                    For Each rule In rules
                       iLogicAuto.RunRuleDirect (rule)
                    Next
                pDoc.Update
                pDoc.Rebuild
                On Error GoTo 10
                pDoc.Save
                pDoc.Close
 Next
Any help is much appreciated. Thanks.
Gus
ac69
Sorry,
for some reason, on my initial post, the part were all the declarations were is missing.
See below again, the full code:
Dim Part_No As String
Dim Part_Name As String
Dim Part_Rev As String
Dim MyFileDirectory
Dim Directory As String
Dim DocType As String
Dim myobject As Document
Dim pDoc As Document
Dim File_Name As String
Dim allModels As Document
Dim fs, f, fl, fc, s
'Get iLogic addins
                        addIn.Activate
    Next
myobject.Close
Set fc = f.Files
For Each fl In fc
                'RunAllRules (pDoc)
                Dim rules As Object
                Stop
                    Next
                pDoc.Update
                pDoc.Rebuild
                On Error GoTo 10
                pDoc.Save
                pDoc.Close
 Next
MjDeck
I found two problems in the code.  The first one is this line:
myobject.Close
At that point you haven't assigned anything to myobject. You should delete that line.
The second one is the line:
rules = iLogicAuto.rules(doc)
rules is an Object.  So you need the Set keyword:
Set rules = iLogicAuto.rules(doc)
I would recommend not running rules that are suppressed.  This gives you a way to disable individual rules without deleting them.  Here's a modified version of your code:
      If (rule.IsActive) Then
   Next
Mike Deck
Software Developer
Autodesk, Inc.
ac69
Hi Mike,
It works now.
Thanks for solution.
ac
