Run Add ins with ilogic
marko.jessenjuhler
marko.jessenjuhler
Is there a way to call the Add-ins application with ilogic.
We have part/drawing export generated with add-in that export material to the PLM system.
Is there a way to run those functions that add in buttons does with logic?
Michael.Navara
For this purposes is in the Inventor.ApplicationAddInServer interface property Automation. You can provide your custom functionality thru this object.
For more information you can see this article
https://adndevblog.typepad.com/manufacturing/2012/07/connect-to-an-inventor-add-in-an-external-appli...
JelteDeJong
There is a second option (that I personally prefer). This option has 2 advantages. In many cases, you don't have to change your adding. There is no need to create/use the Inventor.ApplicationAddInServer interface property Automation. The interface property Automation will always return a object of the type object. maybe not a big deal in iLogic/vb.net (but is very annoying in languages like c#) also you will lose the IntelliSense (code completion) in your code editor.
What you can do: In your rule, add a reference to the DLL of your adding and call its objects directly. For example, you have an adding with the following object:
then you can use them like this in your rule:
AddReference "c:\PATH\To\MyAddin.dll"
Imports MyAddon.NameSpace
' These 2 lines should be at the start of your rule!
Dim myObject As MyObject(ThisApplication)
myObject.showActiveDocumentName()
Jelte de Jong
Blog: hjalte.nl - github.com
