Run a rule on selected parts in assembly.
rafaljarominiak
Observer Observer
rafaljarominiak
Observer
Observer
Hi.
Maybe someone can help me. Is there a way to run an external rule on selected parts in an assembly? I would like to select several parts or subassemblies and run an external rule on them.
Thanks for any help. RJ
C_Haines_ENG
You might want to post this external rule. While this is possible, you need to make sure that you're external rule is written correctly to accept the arguments you want to pass from one to another.
WCrihfield
Not exactly sure how you wanted to handle the selection portion of your request, but I do actually have something that you could likely start with, which matches your request pretty closely.  It lets the user either 'pre-select' assembly components, or if nothing was pre-selected, it lets the user manually select some assembly components after the rule starts.  It then attempts to get the Document object that the components are referencing, and tries to run an external rule on that referenced document.  You will obviously need to change the name of the external rule within this code before trying it out though.
And I also agree with what @C_Haines_ENG said about the contents of the external iLogic rule that this rule will be running.  There are many uniquely iLogic rule objects which try to do tasks in a simpler than usual way, either do not offer a way to specify which document you want it to be focusing on, or offer difficult to understand/use ways of specifying a component or document for it to focus on.  Then there is which document it will focus on when no document is specified, which changes in different situations.  Its all a bit too difficult to explain in one place, but document references become much more critical within external iLogic rules, especially ones that will be ran remotely (due to events triggering them to run, or running them from another document).  This example I have provided offers the most ways to indicate which document you want the 'other' rule to be focused on, but it can not 'force' your other rule to use those tactics/resources.  The other rule has to be designed in a way to work with them.
Sub Main
	Dim oInvApp As Inventor.Application = ThisApplication
	Dim oADoc As AssemblyDocument = TryCast(ThisDoc.Document, Inventor.AssemblyDocument)
	If oADoc Is Nothing Then Return
	Dim oSS As Inventor.SelectSet = oADoc.SelectSet
	Dim oSelected_Occs As New List(Of Inventor.ComponentOccurrence)
	For Each oSSObj In oSS
		If TypeOf oSSObj Is Inventor.ComponentOccurrence Then
			oSelected_Occs.Add(oSSObj)
	Next
	If oSelected_Occs.Count = 0 Then
		Dim oCmdMgr As Inventor.CommandManager = oInvApp.CommandManager
		Dim oFilter = SelectionFilterEnum.kAssemblyOccurrenceFilter
		Dim sPrompt As String = "Select Component - Or Press Esc Key To Exit"
		Dim oPickedOcc As Inventor.ComponentOccurrence = Nothing
		Do
			oPickedOcc = Nothing
			oPickedOcc = oCmdMgr.Pick(oFilter, sPrompt)
			If oPickedOcc Is Nothing Then Exit Do
			oSelected_Occs.Add(oPickedOcc)
		Loop Until oPickedOcc Is Nothing
	Dim sRuleName As String = "EXTERNAL RULE NAME HERE" '<<< CHANGE THIS >>>
	Dim oAuto As IiLogicAutomation = iLogicVb.Automation
	Dim oArgs As Inventor.NameValueMap = oInvApp.TransientObjects.CreateNameValueMap()
	oArgs.Add("Document", Nothing)
	For Each oSelOcc As Inventor.ComponentOccurrence In oSelected_Occs
		Dim oOccRefDoc As Inventor.Document = Nothing
		Try : oOccRefDoc = oSelOcc.ReferencedDocumentDescriptor.ReferencedDocument : Catch : End Try
		If oOccRefDoc Is Nothing Then Continue For
		oArgs.Value("Document") = oOccRefDoc
		oAuto.RunExternalRuleWithArguments(oOccRefDoc, sRuleName, oArgs)
	Next
	oADoc.Update2(True)
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
