Run a calculation before update of model
Basically it's a simple question but i'm struggling 😕
I've made a simple part so it's easier to explain, once i know the mechanics i'll be able to implement it into a bigger program i've written.
I want to know if it's possible to pre-run a calculation on a form before pushing through your values.
I've tried to seperate the coding in two rules: a calculation code and a transfer code but I can't seem to get my head around it *shameful*
Reason: my part is extremely large and by every calculation i don't want it to update straight away ...
Thanks in advance
Hi @Anonymous
if you want to pre-calculate something, just use temporary variables.
For the calculation of a volume this could look like this:
Here the Code of the calculation rule. You write the result to the temporary variable:
Volume_temp = Lenght * Width * Height
Now you display this to the user to check it and if happy with the result run this in the transfer rule:
Volume = Volume_temp
I hope this will end your worries 🙂
If you have any questions or suggestions, please tell me
Would you be so kind to write and adapt this in the code as well?
I tried implementing what you said but i was unsuccessful unfortunately. 😕
For the record: I want to press "Calculation" first to see the volume without changing the model. When i'm satisfied with the Volume i want to press "Transfer" to update the model.
Thanks.
Hi @Anonymous
check this out.
You also have to uncheck the box for automaticly run rule within iLogic.
Didn't know this either 😄
If questions still open, just ask
kelly.young
Autodesk Support
Autodesk Support
@Anonymous did the sample part with code help you out and solve your problem?
If you can post how it turned out or supply a part for better implementation that would be helpful, thanks!
Please select the Accept as Solution button if a post solves your issue or answers your question.
