rules
rules
Message 1 of 10
rules
Dim repMgr As RepresentationsManager = ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager
'record current LevelOfDetailRepresentation
Dim oCurrentRepName As String = repMgr.ActiveLevelOfDetailRepresentation.Name
Dim valore As Double
Dim oRep As LevelOfDetailRepresentation
Dim oRepName
Dim oMass
For Each oRep In repMgr.LevelOfDetailRepresentations
    oRepName = oRep.Name
    'activate this LOD
    repMgr.LevelOfDetailRepresentations.Item(oRepName).Activate
    'get mass
     oMass = iProperties.Mass
     'update value of custom property
     valore = Math.Round(iProperties.Mass/1000,3) & ( Ton )
     iProperties.Value("Custom", oRepName) = valore  &  " Tons "
Next
'restore
repMgr.LevelOfDetailRepresentations.Item(oCurrentRepName).Activate
With this rule found on the net I can create
custom parameters that allow me to calculate the weight of everything that I have not suppressed.
it would be useful to have also the specific gravity (to see if when i have only steel it is correct)
but the density doesn't let me put or recall it
I created another rule
that calculates it but I can not get it to take another parameter name
but specific rule:
dens = iProperties.Mass / iProperties.Volume
iProperties.Value("Custom", "Pes.sp") = Round(dens * 1000 * 1000, 2) & " g/cm^3"
How can I do this?
thank you all you are a great community
Replies (9)
Message 2 of 10
yan.gauthier
In iProperties, symply update the mass. It will ask you if you want to considere suppressed elements or not. You don't need a rule to calculate this. 2021-07-12 10_32_20-14856_01-01-001-000-A (Mass Evaluation) iProperties.png
The mass and density will be updated accordingly
N.B.: *Mass Evaluation is the name of my Level Of Detail
Message 3 of 10
I need a rule that for each weight on the view representation gives me the right density
Message 4 of 10
yan.gauthier
Ok now I understand.
is your issue to get several density iProperties ? then you could change
to
iProperties.Value("Custom", oRepName + "_Density") = Math.Round(dens * 1000 * 1000, 2) & " g/cm^3"
Message 5 of 10
where ai can change?
Message 6 of 10
yan.gauthier
Add this below where you create the Mass property inside the for each loop
Message 7 of 10
Sorry i do not understant
Dim oRepName
Dim oMass
    'activate this LOD
    'get mass
Next
'restore
where i'm insert your solution
Message 8 of 10
yan.gauthier
Dim oRepName
Dim oMass
    'activate this LOD
    'get mass
     iProperties.Value("Custom", oRepName + "_Density") = Math.Round(iProperties.Mass * 1000 * 1000, 2) & " g/cm^3"
Next
'restore
repMgr.LevelOfDetailRepresentations.Item(oCurrentRepName).Activate​
Message 9 of 10
I want the density to material  to determine if it is one material
whit your solution  I get this
Message 10 of 10
Dim oRepName
Dim oMass
    'activate this LOD
    'get mass
     iProperties.Value("Custom", oRepName + "_Density") = (iProperties.Mass / iProperties.Volume)*1000000
Next
'restore
"I found the solution thanks to you you are great"
