rules triggered by events
jletcher
Advisor Advisor
jletcher
I get how you put the rule in but is there a way to remove the rule. I put one in and I don't like how its acting and would like to remove the rule from the list but I see no way do do so....
If you go to the iLogic browser, you should be able to right-click and select delete.
Hope that is helpful, SmokyRick
MegaJerk
Go to your Manage tab, click on the Event Triggers button (in the iLogic section), and then double click the event that you current have rules applied to. A new window will open that will list all of the available rules that you have already set to run with that trigger, or could run with that trigger. Simply un-check the box next to any rule that you don’t want to run with that trigger. If you don’t want any of your rules to run with that trigger, then make sure that all boxes are un-checked.
Further, if you look at the top left corner of the Event Trigger dialog, you have a check box to turn events on or off, completely.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
jletcher
When I click the event trigger all I get is the trigger in my perameters nothing else. I may be asking what I want to do in the wrong fashion. Here is a jpg of the place I want to rule to be removed I put it in the wrong place and wish to remove it but find no way to do so unless I delet the rule and rewrite the rule.
I found this in the help:
Remove a triggered rule from an event
  1. On the ribbon, click Manage tabiLogic panel Event Triggers.
    A dialog box displays the list of available events.
  2. Click the event in the list.
  3. Click Select Rules, or right-click and choose Select Rules from the context menu.
  4. Clear the check mark next to the rule to remove from the event.
  5. Click OK.
  6. Click OK to close the event list.
I found it here:
http://wikihelp.autodesk.com/enu?adskContextId=EVENT_TRIGGERS&language=ENU&release=2013&product=Inve...
Hope this helps more,  SmokyRick
jletcher
Yeah that don't work all that does is stops the rule from running at all. I put it in the wrong spot and wish it not to happen at the time I 1st thought I wanted it to trigger so I moved it to the place I want but can't remove it from the other spot. So it wants to keep running or trigger at the spot I don't want it to.
Now I deleted all rules and put them all back in but there hase to be a way to remove it from the other trigger location. If not Autodesk did not think this all the way through and if you mess up you are screwed.  I did lots of looking and I cannot find anyway to remove them..
jletcher
ok never mind I see my errors in the second window where you select the rule unchek that spot ok my bad I must read all not skip a word or two when I please LOL..
Ok
