Rules for selection set of sketch lines and calculating the length.
william
Message 1 of 1
william
We had some digitized patterns with a lot of small lines, and I needed to get the total lengths for different sections. The obvious method was to use reference dimensions and add them up in a user parameter, but that would've been quite visually distracting and tedious to check the equation.
So, I have created these rules, one to create/modify a selection set that is saved in the part file. Second one gets the lengths of all the lines and adds it to a user parameter for future use, third one can display the lines to verify what is selected.
Seems to be working quite well, no reason it couldn't be modified to create custom selection sets for faces, edges, etc. May be helpful to someone else.
1. Create selection Set
Sub Main()
Dim oDoc = ThisDoc.Document
oCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
userParams = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters
Dim SelectionSet As New ArrayList
For Each oProp In oCustomPropertySet
	If oProp.name.Contains("RefKeys") Then
		SelectionSet.Add(oProp.name)
Next
SelectionSet.Add("Create New?")
SelectedParam = InputListBox("", SelectionSet, SelectionSet, Title := "Available Parameters", ListName := "Please select an Option")
If SelectedParam = "Create New?" Then
	myparam = InputBox("Enter the selection set name", "Title", "Test")
	iProperties.Value("Custom", myparam & "_RefKeys") = ""
	Try
		oParameter = userParams.AddByValue(myparam & "_Value", "", UnitsTypeEnum.kMillimeterLengthUnits)
	Catch
		'Parameter already exists
	End Try
	SelectionSet.Add(myparam & "_RefKeys")
	SelectedParam = myparam & "_RefKeys"
Dim oHSet As HighlightSet = oDoc.CreateHighlightSet()
oHSet.Color = ThisApplication.TransientObjects.CreateColor(185, 0, 0) 'Red
Start :
Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveFilter, "Select a line")
oDoc.SelectSet.Select(entity)
oLine = oDoc.SelectSet.Item(1)
Dim refKey() As Byte = New Byte() {}
oLine.GetReferenceKey(refKey)
Dim strRefKey As String = ThisDoc.Document.ReferenceKeyManager.KeyToString(refKey)
Dim strAccumulatedRefKey As String = strAccumulatedRefKey & "," & strRefKey
oHSet.AddItem(oLine)
Q = MessageBox.Show("Select another edge?", "Create Selection Set", MessageBoxButtons.YesNo)
oDoc.SelectSet.Clear()
If Q = vbYes Then
	GoTo Start
iProperties.Value("Custom", SelectedParam) = strAccumulatedRefKey
oHSet.Clear()
End Sub
2. Compute selection sets
Sub Main()
Dim strParamNameArray() As String
Next
If SelectionSet.Count <= 0 Then
 Exit Sub
For i = 0 To SelectionSet.Count - 1
	strParamNameArray = SelectionSet(i).Split("_")
	ParameterName = strParamNameArray(0)
	ParamExists = False
	Dim strRefKeysArray() As String
	strRefKeysArray =  iProperties.Value("Custom", SelectionSet(i)).Split(",")
	AccumulatedLength = 0
	For j = 1 To strRefKeysArray.Count - 1
		Dim strRefKey As String = strRefKeysArray(j)
	    Dim refKeyMgr As ReferenceKeyManager = oDoc.ReferenceKeyManager
	    Dim edgeRefKey = New Byte() {}
	    Call refKeyMgr.StringToKey(strRefKey, edgeRefKey)
		Dim foundObject As Object = refKeyMgr.BindKeyToObject(edgeRefKey)
		If TypeOf foundObject Is Inventor.SketchLine Then
		    Dim foundLine As SketchLine
		    foundLine = refKeyMgr.BindKeyToObject(edgeRefKey)
			Length = foundLine.Length
		ElseIf TypeOf foundObject Is Inventor.SketchArc Then
		    Dim foundArc As SketchArc
		    foundArc = refKeyMgr.BindKeyToObject(edgeRefKey)
			Length = foundArc.Length
		Else
			Length = 0
		   	'Found object type is not supported
		AccumulatedLength += Length
	Next
		For Each oParam In userParams
			If oParam.Name.Contains(ParameterName & "_Value") Then
				ParamExists = True
				Parameter.Param(oParam.Name).Value = AccumulatedLength
		Next
	If ParamExists = False Then
		'MessageBox.Show("ParameterName: " & ParameterName, "Title")
		oParameter = userParams.AddByValue(ParameterName & "_Value", AccumulatedLength, UnitsTypeEnum.kMillimeterLengthUnits)
Next
RuleParametersOutput()
iLogicVb.UpdateWhenDone = True
End Sub
3. Display Selection Sets
Sub Main()
Next
 Exit Sub
	ParamExists = False
	    ' Bind back the item.
	    Dim foundEdge As Object
	    foundEdge = refKeyMgr.BindKeyToObject(edgeRefKey)
		oHSet.AddItem(foundEdge)
	Next
	MessageBox.Show("Lines displayed for: " & SelectionSet(i))
	oHSet.Clear()
Next
End Sub
Replies (0)
