Rule to suppress features containg certain word
fakeru
fakeru
Hi
Would it be possible that a rule can suppress all part's features that contain in their name a certain word.
I use to rename features for better workflow. More features that form a part of the model can contain same word, for instance "foot": foot_extrusion; foot_plate and so on.
When working with ilogic I have to specify each feature name, but I was thinking that may be would be easier to suppress the features by their name.
Alexandru
Autodesk Inventor 2015 Certified Professional
rossano_praderi
Hi Alexandru,
this piece of code che be your solution...
Sub Main
	Fsuppress(True)
	Fsuppress(False)
End Sub
Private Sub Fsuppress(suppress As Boolean)
myparam = InputBox("Feature Name", "Feature suppress", "")
If myparam <> "" Then
	Dim oDoc as PartDocument
	oDoc = ThisApplication.ActiveDocument
	Dim oFeature As PartFeature
	For Each oFeature In oDoc.ComponentDefinition.Features
		If oFeature.Name.ToUpper.Contains(myparam.ToUpper) Then
			oFeature.Suppressed = suppress
			oDoc.Update
	Next
End Sub
 Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
fakeru
Thank you, this is almost what I wanted.
The difference is that, I don't need the input window.
For example I want a rule when it will be run to suppress al features with "nozzle" word in their name.
I tried to adapt the code, but didn't manage 😞
rossano_praderi
Hi Fakeru, let me know if this is helpful to you.
myparam = "YOUR TEXT"
	oFeature.Suppressed = True
	oDoc.Update
Next
Bregs
Rossano Praderi
fakeru
Yes, it works! Thank you so much!
rossano_praderi
You are welcome.
