Rule to PDF all drawings with Part Number instead of File Name
matthew.johnson200
matthew.johnson200
Hi, I have 2 iLogic rules which both PDF drawings. One PDFs just a single drawing, whichever drawing on the screen when the rule is run. The other PDFs all the drawings in the same folder as where the currently opened drawing is saved. The problem I have is the single PDF rule saves the file with part number and revision, whereas the one which saves multiple saves the file name and revision instead. Sometimes in our company these are different as we use an internal numbering system for the file name, but sometimes we needs a suppliers number which we put in the part number. I would like the multiple PDF rule to export the PDF with the part number & revision. I'm sure its relatively simple but I cant figure it out. the 2 rules are below.
Thanks in advanced.
Single PDF Rule (working fine):
Sub Main()
Dim oDoc As Document
oDoc = ThisDoc.Document
Dim PDFAddIn As TranslatorAddIn
Dim oContext As TranslationContext
Dim oOptions As NameValueMap
Dim oDataMedium As DataMedium
Call ConfigurePDFAddinSettings(PDFAddIn, oContext, oOptions, oDataMedium)
oFolder = "C:\Pdfs"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
	MessageBox.Show("DRAWINGS WILL BE SAVED IN C:\Pdfs", "PDF")
'oBaseName = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
oBaseName = iProperties.Value("Project", "Part Number")
oBaseName=oBaseName & "-" & iProperties.Value("Project", "Revision Number")
oDataMedium.FileName = oFolder & "\" & oBaseName & ".pdf"
Call PDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
End Sub
Sub ConfigurePDFAddinSettings(ByRef PDFAddIn As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
oOptions.Value("Custom_Begin_Sheet") = 1
oOptions.Value("Custom_End_Sheet") = 1
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
End Sub
 Multiple PDF Rule (To be changed to use the part number instead of file name):
 Sub Main
    Dim processPath As String
	oFolder = "C:\Pdfs"
	CurFileName = oDoc.FullFileName
	FNamePos = InStrRev(CurFileName, "\", -1)
	Name = Right(CurFileName, Len(CurFileName) - FNamePos)
	processPath = Left(CurFileName, Len(CurFileName) - Len(Name))
    Dim filenames() As String
    filenames = System.IO.Directory.GetFiles(processPath, "*.dwg")
    For Each filename As String In filenames
	 	oDoc=ThisApplication.Documents.Open(filename, True)
		oBaseName = System.IO.Path.GetFileNameWithoutExtension(filename)
		oBaseName=oBaseName & "-" & oDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
    Next
End Sub
End Sub
Curtis_Waguespack
@matthew.johnson200 , this should work.
Hope that help, Curtis
Sub Main
	oFolder = "C:\Pdfs"
	Name = Right(CurFileName, Len(CurFileName) -FNamePos)
	processPath = Left(CurFileName, Len(CurFileName) -Len(Name))
		oDoc = ThisApplication.Documents.Open(filename, True)
		oPartNumber = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
		oRevNumber = oDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
		oBaseName = oPartNumber & "-" & oRevNumber
	Next
End Sub
End Sub
matthew.johnson200
That works great. Exactly what I wanted.
Thanks for your help!
