rule to generate iparts members and export them in stp format
Message 1 of 1
I have a problem. I made an ipart and by it I have to generate 2000 / 3000 members ,then I have to export them in step format.
At the moment I generate the parts, then I put all of them in an assembly and by a rule I export automatically in step format every part.
I ask you if you are able to write a rule to do it togheter: I like to create a rule that generates all members of ipart and convert every member generated in step format, is it possible?
I ask you an help because I am not so good with VB .
Thanks in advance
Replies (0)
