Rule to Copy File Name to Description, Assembly Level
emanuel.c
emanuel.c
I have this rule to copy file name to description for all parts and subassemblies in an assembly. However, at the end of the description I also get the occurrence number, such as ":2" if the part is used twice in an assembly. How can I copy only the filename?
Thank you!
'For each occurence in an assembly copy file name to description
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences in the assembly
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
    Dim oName As String
    oName = oOccurrence.Name
    'Fill in part Description from File Name
	iProperties.Value(oOccurrence.Name, "Project", "Description") = oName
Next
A.Acheson
Here is a post that deals with that but trying to use it in a different way.
The (0) in the array represents the first segment of the string, if you type (1) you get the second segment.
The snippet for your purpose.
oNameArray = Split(oName, ":") oName = oNameArray(0) Try iProperties.Value(oOccurrence.Name, "Project", "Description") = oName
Catch
End Try
You can also find that function by declaring oName as string and get split in the drop down.
Some more info on string functions
https://docs.microsoft.com/en-us/dotnet/visual-basic/language-reference/functions/string-functions
Regards
Alan
emanuel.c
That's beautiful and thank you for the link! A lot of good info there.
