rule to auto update and save drawing to pdf
mitoborecek
Message 1 of 33
mitoborecek
How to make/run rule in drawing .dwg after change all parapeters and autoremodel assemble .iam.
When run rule in drawing I need tu update drawing (take about 10-15 sec) and save as .pdf with name (some parameter in assemble)
Replies (32)
Message 2 of 33
JoAntt
try this!
Update
InventorVb.DocumentUpdate()
Save pdf
ThisDoc.Document.SaveAs((Path to new pdf"), True)
Message 3 of 33
mitoborecek
Doesnt work
Message 4 of 33
J-Camper
@mitoborecek,
I've never tried the save as approach, but i know this works:
Sub Main
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
	'UPDATE
	'Create PDF
	Call CreatePDFExport(ThisApplication.ActiveDocument)
End Sub
Private Sub CreatePDFExport(dDoc As DrawingDocument)
	' Create a DataMedium object
	Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
	'Set the destination file name
	oDataMedium.FileName = System.IO.Path.ChangeExtension(dDoc.FullFileName, ".pdf")
	' Get the PDF translator Add-In.
	Dim PDFAddIn As TranslatorAddIn
	PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	' Create a NameValueMap object
	Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
	' Check whether the translator has 'SaveCopyAs' options
	If PDFAddIn.HasSaveCopyAsOptions(dDoc, oContext, oOptions) Then
		' Options for drawings...
		oOptions.Value("All_Color_AS_Black") = 0
		oOptions.Value("Remove_Line_Weights") = 0
		oOptions.Value("Publish_All_Sheets") = 0
		oOptions.Value("Launch_Viewer") = 0
		oOptions.Value("Vector_Resolution") = 2400
		oOptions.Value("Sheet_Range") = PrintRangeEnum.kPrintAllSheets
		'oOptions.Value("Custom_Begin_Sheet") = 2
		'oOptions.Value("Custom_End_Sheet") = 4
	'Publish document.
	Try
		Call PDFAddIn.SaveCopyAs(dDoc, oContext, oOptions, oDataMedium)
	Catch ex As Exception
		MessageBox.Show(ex.Message, "Export Error")
	End Try
End Sub
The sub routine will currently save the PDF in the same location as the drawing, but you can change that by supplying the location to the Sub routine "CreatePDFExport"
Let me know if you have any questions
Message 5 of 33
mitoborecek
it works fine but it print to pdf all layouts. Need print to pdf only "4 sachta:1"
How to edit rule to name it - some parameter from asseble?
Message 6 of 33
J-Camper
if you have that sheet active, you could change the options in the PDF sub like this:
oOptions.Value("Sheet_Range") = PrintRangeEnum.kPrintCurrentSheet
If the intended sheet is always sheet 1 then you could do this:
oOptions.Value("Sheet_Range") = PrintRangeEnum.kPrintSheetRange
oOptions.Value("Custom_Begin_Sheet") = 1
oOptions.Value("Custom_End_Sheet") = 1
 Options part:
Message 7 of 33
mitoborecek
This works perfect
Noe just to change the name when saving the pdf - either according to some parameter in the assemble, which changes every time, or just from number 1, 2, 3 ...
Message 8 of 33
J-Camper
@mitoborecek,
I replaced the filename creation with a custum function:
Sub Main
	'UPDATE
	'Create PDF
End Sub
	oDataMedium.FileName = GetPDFFileName(dDoc)
	'Publish document.
	Try
	End Try
End Sub
Function GetPDFFileName(dDoc As DrawingDocument) As String
	Dim FileName As String = System.IO.Path.ChangeExtension(dDoc.FullFileName, ".pdf")
	Dim UserProperties As PropertySet = dDoc.PropertySets.Item("Inventor User Defined Properties")
	Dim IssueIndex As String
	Try
		IssueIndex = UserProperties.Item("Issue Index").Value
	Catch
		UserProperties.Add("1", "Issue Index")
	End Try
	FileName = String.Format("{0}({1}){2}", Left(FileName, FileName.Length-4), IssueIndex, Right(FileName, 4)).ToString
	Return FileName
End Function
This uses an iProperty in the drawing file, and requires manual change.  Didn't think you would want it to increment automatically.
Message 9 of 33
mitoborecek
After change in my asssembly one of my parameters "Name" change value every time, when I change specific parameters in assembly.
This parameter "Name" will be perfect to use as name in drawing rule to named pdf
Message 10 of 33
J-Camper
@mitoborecek,
Replace the GetPDFFileName function with this:
	Dim IssueIndex As String = "Missing Reference Assembly"
	If dDoc.ReferencedDocuments.Count > 0
		Dim aDoc As AssemblyDocument = TryCast(dDoc.ReferencedDocuments.Item(1), AssemblyDocument)
		If aDoc IsNot Nothing
			Try
				IssueIndex = aDoc.ComponentDefinition.Parameters.Item("Name").Value.ToString
			Catch
				IssueIndex = "Missing_Name_Parameter"
			End Try
	Return FileName
End Function
Message 11 of 33
johan.degreef
@J-Camper
Dear, what should I change to this code if I want to save it to a networkshare ex. "\\192.168.1.1\pdf-inventor"?
Many Thanks, Johan
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Message 12 of 33
mitoborecek
last 2 things
- name - just parameter "Name" without filename and "()"
- how to auto run this rule in drawing after all changes made in assemble?
Message 13 of 33
J-Camper
@johan.degreef,
Replace the FileName line with this:
Dim FileName As String = "\\192.168.1.1\pdf-inventor\" & System.IO.Path.GetFileNameWithoutExtension(dDoc.FullFileName) & ".pdf"
Message 14 of 33
J-Camper
@mitoborecek,
The filename is easy,  Replace the GetFileName Function again:
	Dim FileName As String = System.IO.Path.GetDirectoryName(dDoc.FullFileName) & "\"
			Try
			Catch
			End Try
	FileName = String.Format("{0}{1}{2}", FileName, IssueIndex, ".pdf").ToString
	Return FileName
End Function
As far as triggering the rule to run, you could set it to an event trigger:
Message 15 of 33
mitoborecek
but I need run "rule 2" in drawing, after finish "rule 1" in assembly
Message 16 of 33
J-Camper
with it set  to an event trigger "Drawing View Update".  It should run automatically when you open the drawing after making changes to the assembly because the drawing view will be updating
The other thing you could do is combine rules 1 & 2 so you make changes to assembly, then the rule opens the drawing and executes on the opened drawing.  I would need more context to help with this.
Message 17 of 33
mitoborecek
I change assembly meny times but dont close assembly (inventor) and update drawing after change assembly. Then save drawing to pdf. So
0. Open assembly
1. Make change in assembly
2. update drawing, then save pdf
3. make change in assembly
4. update drawing, then save pdf
5. close program
Message 18 of 33
J-Camper
Did you try the event trigger?  It should trigger the rule to run when you activate the drawing after making changes to the assembly.  Your process would be the same, Edit assembly then switch tabs to drawing [which triggers the rule to run as drawing views update], then switch back to the assembly and make more changes.
Message 19 of 33
mitoborecek
I dont switch between assembly and drawing. I am in drawing, and run rule with changes use Forms. After changes I click on update icon in drawing
Message 20 of 33
J-Camper
Easiest thing to do is add a Run other rule call at the end of your current rule:
iLogicVb.RunRule("ruleName")
Otherwise you can do my suggestion about merging the 2 rules.  It should be easy enough to just move your current rule into the Sub Main portion of the rule I posted above the up date call, and Export PDF call.  Then you only have to run 1 rule that will do everything it does now then updates and creates PDF.
In order for me to help with merging I need the other rule.
