Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Rule searches for virtual parts.
tecnico
tecnico
Hello everyone, I've tried searching but I can't find a solution to my problem. I need to create a rule that checks if, in my assembly (only first level), there is a Virtual Part with the same name as the assembly.
thank
WCrihfield
Hi @tecnico.  Here is something you can try for that task.  First, it makes sure it is working with an assembly (not a part or drawing).  Then it gets the components collection.  Then iterates through them, skipping any that are suppressed, and if a 'virtual' one is found, it compares the first part of that components name to the DisplayName of the main assembly.  If a match is found, a message will pop-up and let you know.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
		Exit Sub
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
	For Each oOcc As ComponentOccurrence In oOccs
		If oOcc.Suppressed Then Continue For 'cant access Definition if Suppressed
		If TypeOf oOcc.Definition Is VirtualComponentDefinition Then
			If oOcc.Name.StartsWith(oADoc.DisplayName) Then
				MsgBox("Found a Virtual component with same name as main assembly.", vbInformation, "iLogic")
	Next 'oOcc
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
tecnico
Hello, thank you for the response. I tried the rule you wrote, but I don't get any effect. I created a virtual part with the same name as the assembly from which I launch it, the rule runs but nothing happens. Rather than the assembly name, I would need it to look at the part number though.
Thank you.
WCrihfield
Hi @tecnico.  OK.  Here is a slightly different version of the code, but this version compares the Part Number of the main assembly to the Part Number of the virtual component.  And also uses a Boolean to let you know if no match was found after the loop.
Sub Main
		Exit Sub
	Dim sAssemblyPN As String = oADoc.PropertySets.Item(3).Item(2).Value
	Dim bFound As Boolean = False
			Dim oVCD As VirtualComponentDefinition = oOcc.Definition
			Dim sVOccPN As String = oVCD.PropertySets.Item(3).Item(2).Value
			If sVOccPN.Equals(sAssemblyPN, StringComparison.CurrentCultureIgnoreCase) Then
				bFound = True
				MsgBox("Found a Virtual component with same Part Number as main assembly.", vbInformation, "iLogic")
	Next 'oOcc
	If bFound = False Then
		MsgBox("Did not find a Virtual component with same Part Number as main assembly.", vbInformation, "iLogic")
End Sub
Wesley Crihfield
