Rule :Model to PDF
Rule :Model to PDF
firelinsgs
Rule :Model to PDF
firelinsgs
I have this code to export all parts to IMAGE file . But now i need to change to export all parts to PDF. I tried to edit the rule myself, but unsuccessfully.
Thansk,
Sub Main
	Dim oDoc As Document = ThisDoc.Document
	Dim oDocName As String = System.IO.Path.GetDirectoryName(oDoc.FullFileName) & "\" & System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
	If Not (oDoc.DocumentType = kAssemblyDocumentObject Or oDoc.DocumentType = kDrawingDocumentObject) Then
		MessageBox.Show("  " , "iLogic")
		Exit Sub
	For Each oRefDoc As Document In oDoc.AllReferencedDocuments
		DoBMP (oRefDoc)
	Next
End Sub
Sub DoBMP (ByVal aDoc As Document)
	Dim oDoc As Document = Nothing
	Try
		oDoc = ThisApplication.Documents.Open(aDoc.FullFileName, True)
        Dim FName As String = GetFName(oDoc.FullFileName)
		Dim sPN As String = iProperties.Value("Project", "Part Number")
		Dim sPNS = Mid(sPN, 7, 3)
		Dim sPZ As String = vbNullString
		If Not IsNumeric(sPNS) Then Exit Sub
		If Len(sPN) >= 3 Then sPZ = Left(sPN, 3) Else sPZ = sPN
        If iProperties.Value(FName, "Project", "Cost Center") = "V" Then Return
        If Val(sPN) >= 3 And Val(sSZ) < 900 Then Return
'		Dim FName As String = oDoc.FullFileName
		Dim FNP As Integer = InStrRev(FName, "\", -1)
		FName = Mid(FName, FNP + 1)
		Dim oDTPs As PropertySet = oDoc.PropertySets.Item("Design Tracking Properties")
		Dim oPN As String = oDTPs.Item("Part Number").Value
		oPathAndName = Replace(oDoc.FullFileName, FName, oPN)
		Dim m_CV As Inventor.View = ThisApplication.ActiveView
		Dim m_Camera As Inventor.Camera = m_CV.Camera
		Dim m_TO As Inventor.TransientObjects = ThisApplication.TransientObjects
		m_Camera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
		m_Camera.Fit()
		m_Camera.ApplyWithoutTransition()
		Dim m_PrevMode As Integer = m_CV.DisplayMode
		Dim m_Disp3D As Boolean = ThisApplication.DisplayOptions.Show3DIndicator
		m_CV.DisplayMode = Inventor.DisplayModeEnum.kShadedWithEdgesRendering
		ThisApplication.DisplayOptions.Show3DIndicator = False
		m_CV.Update()
		Dim oPath As String = "C:\PDF"& oPN &".jpg"
		If IO.File.Exists(oPath) Then IO.File.Delete(oPath)
		m_Camera.SaveAsBitmap(oPath, 800, 600, m_TO.CreateColor(255,255,255))
		m_CV.DisplayMode = m_PrevMode
		ThisApplication.DisplayOptions.Show3DIndicator = m_Disp3D
		m_CV.Update()
	Catch ex As Exception
		MsgBox(ex.Message)
	Finally
		If oDoc IsNot Nothing Then oDoc.Close(True)
	End Try
End Sub
Function GetFName(FullName As String) As String
	Dim FNP As Integer = InStrRev(FullName, "\", - 1)
	Dim FName As String = Mid(FullName, FNP + 1, Len(FullName) - FNP)
	Return FName
End Function
firelinsgs
Anyone please?
