Rule for scaling up the cad model by 2: not running: is my script right?
nirajan7BV4D
nirajan7BV4D
hi all, i am trying to write a rule that scales up some of the sizes of my cad model by 2. however, when i hit save and run button, it is saved and appears on the ilogic browser but it doesnt run. can somebody check if the way i am writing the script is correct or not? would really appreciate, i am a begginer, thanks!Capture.PNGginner. thanks!
WCrihfield
Can you post the code you have here, so we can check to see if there might be anything wrong with that part?
What version of Inventor are you using (2019, 2020, 2021, 2022)?  When you have that rule open in the iLogic rule editor dialog, go to the Options tab at the top and look at those settings.
Make sure the Suppressed option is not checked.
Also, back out in Inventor's main window, on the Tools tab > Options panel, there should be a tool to click called iLogic Configuration (you may have to expand the bottom of the panel to see it).  You can check out the settings within that dialog to see if everything looks as you expect it to.  Those settings mostly effect external rules, though.
Wesley Crihfield
(Not an Autodesk Employee)
