Rule flat pattern export fails, when custom property is not created
vkulikajevas
vkulikajevas
I have this Flat pattern rule. The problem comes with naming. When part does not have a Custom parameter (iQTY), rule does not export DXF.
Can this line be tweaked, so that when iQTY does not exist, it would just insert nothing and export anyway?
Dim oDoc As Document = ThisDoc.Document
'Dim ovnt As String = InputBox("Detalių kiekis", "VNT", "1")
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
		If oCompDef.HasFlatPattern = False Then
			oCompDef.Unfold
		Else
			oCompDef.FlatPattern.Edit
		Try
			oMaterial = oDoc.ComponentDefinition.Material.Name
			oThickness = Round(oDoc.ComponentDefinition.Thickness.Value*10, 2)'Convert cm to inch
			oStockNumber = oDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value
			oDescription = oDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
			oPartNumber = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
			iQTY = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("iQTY").Value
			Dim oFilename As String  = ThisDoc.Path & "\" &  oPartNumber  & " " & oMaterial & " " & oStockNumber & " " & iQTY  & "vnt.dxf"
			MessageBox.Show(oFilename)
			Dim oDataIO As DataIO = oDoc.ComponentDefinition.DataIO
    		oDataIO.WriteDataToFile("FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&InvisibleLayers=IV_ARC_CENTERS;IV_TANGENT;IV_ROLL;IV_ROLL_TANGENT;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_FEATURE_PROFILES_DOWN;IV_FEATURE_PROFILES;IV_TOOL_CENTER_DOWN;IV_BEND;IV_BEND_DOWN", oFilename)
			oCompDef.FlatPattern.ExitEdit
		Catch
		End Try
WCrihfield
How about if that variable is set to an empty string, when that custom property doesn't exist.  Then you don't have to alter your complicated file name string.  You can do that like this:
Replace this line:
with this block of code:
Dim iQTY As String
Try
Catch
	iQTY = ""
End Try
You could also use that Catch portion of the Try...Catch block to create the custom iProperty if you wanted.  Or to run some other rule or sub that would create it, and set its value.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
