Rule crashes when run twice - shrinkwrap
dialunau
Message 1 of 8
dialunau
Hello everyone,
I'm making a rule that creates a shrinkwrap of a part in an assembly, save that shrinkwrap part and then place it in the original assembly. My rule works perfectly fine when I run it the first time, however, it always crashes when I run it a second time. Then if I run it a third time it works fine, but the fourth time it crashes again and so on. The problem seems to be in the line that makes the .saveas command.
Any ideas of what is happening and how to fix it?
Here is my code:
Sub Main()
    Dim oAssy As AssemblyDocument = ThisApplication.ActiveDocument
    Dim oAssyDef As AssemblyComponentDefinition = oAssy.ComponentDefinition
    'Select the occurrences
	Dim oOcc1 As ComponentOccurrence = ThisApplication.CommandManager.Pick(kAssemblyLeafOccurrenceFilter,"Select the first occurrence")
    Dim oOcc2 As ComponentOccurrence = ThisApplication.CommandManager.Pick(kAssemblyLeafOccurrenceFilter,"Select the second occurrence")
    Dim oOcc1Def As PartComponentDefinition = oOcc1.Definition
	Dim oSWPath As String
	oSWPath = SWrap(oAssy, oAssyDef, oOcc2, oSWPath)
	Call AddToAssy(oAssyDef, oSWPath)
End Sub
Function SWrap(oAssy As AssemblyDocument, oAssyDef As AssemblyComponentDefinition, oOcc2 As ComponentOccurrence, oSWPath As String)
	Dim oSWDoc As PartDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject)
	Dim oSWD As ShrinkwrapDefinition = oSWDoc.ComponentDefinition.ReferenceComponents.ShrinkwrapComponents.CreateDefinition(oAssy.FullDocumentName)
	Dim oExclude As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	Dim oOcc As ComponentOccurrence
	'Add only the second occurrence
	For Each oOcc In oAssyDef.Occurrences
		If Not oOcc Is oOcc2 Then
			Call oExclude.Add(oOcc)
	Next oOcc
	oSWD.AdditionalExcludedOccurrences = oExclude
	oSWD.RemoveHolesStyle = ShrinkwrapRemoveStyleEnum.kShrinkwrapRemoveAll
	oSWD.BreakLink = True
	Dim oSWComp As ShrinkwrapComponent
	oSWComp = oSWDoc.ComponentDefinition.ReferenceComponents.ShrinkwrapComponents.Add(oSWD)
	oSWPath = ThisDoc.PathAndFileName(True) & "_SW.ipt"
	'//// Delete previous file if it already exists ////
	If System.IO.File.Exists(oSWPath) = True Then
		System.IO.File.Delete(oSWPath)
	oSWDoc.SaveAs(oSWPath, False) '/ THE CODE CRASHES EXACTLY AT THIS LINE EVERY SECOND TIME I RUN IT /
	oSWDoc.Close
	Return(oSWPath)
End Function
Sub AddToAssy(oAssyDef As AssemblyComponentDefinition, oSWPath As String)
	Dim oMat As Matrix = ThisApplication.TransientGeometry.CreateMatrix()
    oMat.SetTranslation(ThisApplication.TransientGeometry.CreateVector(0, 0, 0))
	Dim oNewOcc As ComponentOccurrence = oAssyDef.Occurrences.Add(oSWPath, oMat)
End Sub
Replies (7)
Message 2 of 8
WCrihfield
Hi @dialunau.  This is just somewhat of an educated guess, but after reviewing this it seems a bit odd to be setting the initial value of the oSWPath variable using a function which requires that oSWPath as one of its input variables.  Seems like a circular paradox situation (the function needs to run in order to set its value, but the function needs an initial value to run).  Also, the one line you are using within the function to re-set the value of oSWPath seems a bit ambiguous, because it uses the term "ThisDoc", which can be pointing to different documents in different situations.  Just my initial thoughts.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 8
WCrihfield
Also, if the term 'ThisDoc' within your function is supposed to be referring to the new PartDocument that you just created, that new PartDocument will not have a path or file name yet, because it has not been saved yet, which will cause a problem when you try to get it with that line of code.  Then when you run it the second time, maybe it is still seeing the previously created new PartDocument which has been saved, and uses its path and file name in that second run.  Just some more thoughts.
Wesley Crihfield
Message 4 of 8
dialunau
Thanks for the comments.
I fixed those inconsistencies by defining the path as the assembly path which is already saved in the location, and replacing the 'ThisDoc' line with the part document variable 'oSWDoc'.
Even so, the code still crashes when I run it twice.
Here are the changes I made:
Sub Main()
	Dim oSWPath As String = oAssy.FullDocumentName & "_SW.ipt" '// fixed so it has a reference to an already saved document //
	Call SWrap(oAssy, oAssyDef, oOcc2, oSWPath)
End Sub
Sub SWrap(oAssy As AssemblyDocument, oAssyDef As AssemblyComponentDefinition, oOcc2 As ComponentOccurrence, oSWPath As String)
	Next oOcc
	'/// Delete previous file if it already exists ///
	oSWDoc.SaveAs(oSWPath, False) '/// The code still crashes at this exact line ///
	oSWDoc.Close
End Sub
End Sub
Message 5 of 8
Michael.Navara
Deleting a file that may be open in inventor is very dangerous and may cause unexpected behavior.
Replace this part of your code with something different. For example generate new sequentially numbered file name.
Message 6 of 8
dialunau
I edited that fragment to instead of deleting the file, make the new file sequential.
No luck, the code still crashes at that specific line.
Message 7 of 8
SevInventor
Hello
Hello dialunau
if you add the timestring to the filename you can avoid multiple same filenames.
There are no Errors when i tested it
	Dim oTime as string = TimeString
	oTime = Replace(oTime, ".", "-")
	oTime = Replace(oTime, ":", "-")
	Dim oSWPath As String = oAssy.FullDocumentName & oTime & "_SW.ipt" '// fixed so it has a reference to an already saved document //
Message 8 of 8
whashtonjrGV2BR
Hi dialunau.
Maybe it might be the IO method is general .Net and the save method built in is likely VB specific?
You might want to try the VB methods "My.Computer.FileSystem.FileExist("C:\test.txt")" "My.Computer.FileSystem.DeleteFile("C:\test.txt")".
It might be "InventorVb.Application.FileManager.DeleteFile()" in iLogic.
Here's a link for more detail How to: Delete a File - Visual Basic | Microsoft Docs and  FileSystem.FileExists(String) Method (Microsoft.VisualBasic.FileIO) | Microsoft Docs
Hope that helps.
Bill Ashton
