Rule compile error not member Integer: iLogic Hole pattern control
frank5838S
Message 1 of 1
frank5838S
Hi all,
I'm trying to add a hole pattern in a part (weather louvre) according a manufacturer datasheet (attached) but I'm getting compile errors: Value is not a member of Integer.
Hole pattern changes at certain steps, in width and height, I started with the Width.
I made the part, added User parameters T1, T2 and Gat_n (array distance) and made the sketch/feature for the first hole. After that added an array and used the User Parameters where needed.
This is what I have now (width only) but getting these compile errors.
Pattern for the height still to be added when this first step works.
' === Access the User Parameters ===
Dim louvreWidth As Double
louvreWidth = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("Rooster_Breedte").Value ' Get the value for width (double type)
' Output values
Dim Gat_n As Integer ' Hole count (replacing Gat_Aantal)
Dim edgeDistanceT2 As Double ' Distance from the side of the louvre (double type)
' === Logic to Determine Hole Count (Gat_n) ===
If louvreWidth >= 165 And louvreWidth <= 384 Then
    Gat_n = 1
ElseIf louvreWidth >= 385 And louvreWidth <= 881 Then
    Gat_n = 2
ElseIf louvreWidth >= 882 And louvreWidth <= 1481 Then
    Gat_n = 3
ElseIf louvreWidth >= 1482 And louvreWidth <= 2081 Then
    Gat_n = 4
ElseIf louvreWidth >= 2082 And louvreWidth <= 2399 Then
    Gat_n = 5
Else
    ' Default or further logic for widths larger than 2399
    Gat_n = 6
' === Edge Distance (T2) Calculation ===
If Gat_n = 1 Then
    edgeDistanceT2 = louvreWidth / 2 ' Centered if only 1 hole
Else
    edgeDistanceT2 = 80 ' Fixed offset for multiple holes
' === Spacing Calculation (T1) ===
If Gat_n > 1 Then
    ' Directly assign the calculated spacing to the T1 parameter
    ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("T1").Value = (louvreWidth - 2 * edgeDistanceT2) / (Gat_n - 1)
Else
    ' If there is only one hole, spacing is not necessary
    ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("T1").Value = 0
' === Writing back to User Parameters ===
' Set values for Gat_n (hole count) and T2 (edge distance)
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("Gat_n").Value = Gat_n
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("T2").Value = edgeDistanceT2
Replies (0)
