Routine for turn visible on for all components
I want a routine where I can turn Visibility on, for all components.
This is my code, something is wrong.
thanks
Private Sub CommandButton9_Click()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim odef As AssemblyComponentDefinition
Set odef = oDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
For Each oOcc In odef.Occurrences
oDoc.SelectSet.Select oOcc
oOcc.Visible = True
Next
End Sub
psaarloos
Hi Henrik.
Just delete the line oDoc.SelectSet Select oOcc. Then it should work... It only works for first level occurrences though.
Otherwise you can make a routine:
Public Sub SetAssemblyVisibility(ByVal oAssemblyDocument As AssemblyDocument, ByVal bVisible As Boolean)
dim oComponentOccurrence As ComponentOccurrence
For Each oComponentOccurrence In AssemblyDocument.ComponentDefinition.Occurrences
If oComponentOccurrence.Definition.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
oComponentOccurrence.Visible = Visible
Call SetAssemblyVisibility(oComponentOccurrence.Definition.Document, Visible)
Else
Next
End Sub
After making this routine, just call the routine from your button click event:
call SetAssemblyVisibility(thisapplication.activedocument, true) <-- or false if you want to turn off visibility for all occurrences.
Kind regards,
Pim Saarloos
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
psaarloos
mmm... this one should work beter.. 😉
For Each oComponentOccurrence In oAssemblyDocument.ComponentDefinition.Occurrences
oComponentOccurrence.Visible = bVisible
Call SetAssemblyVisibility(oComponentOccurrence.Definition.Document, bVisible)
Else
Next
End Sub
Pim Saarloos
Product Manager
Hi Psaarloos.
I've tried your code, but I got an error in line 4 "if ...." I can't see
what's wrong.
thanks Henrik
Dim oComponentOccurrence As ComponentOccurrence
bVisible)
Else
Next
End Sub
skrev i en meddelelse news:5940476@discussion.autodesk.com...
bVisible)
Else
Next
End Sub
... on error resume next solved the problem...
"Henrik Villars" skrev i en meddelelse
news:5940782@discussion.autodesk.com...
Hi Psaarloos.
what's wrong.
thanks Henrik
Visible = bVisible
bVisible)
Else
Next
End Sub
oAssembly
bVisible)
Else
Next
End Sub
