Rounding dimension values
Way to round decimal dimension values to the nearest 1/16"? For instance,
43.0599 would display as 43.0625 (On a drawing). Tried playing with
tolerances, but thought it would be better addressed as customization.
Thanks in advance...
A customer gave me a reference to a website a few weeks ago that contained a
sample that converted a number into a fraction. I modified that code so
that outputting a fraction is outputs a decimal value but rounded off to the
nearest specificied fractional value. In the example below, the 16 says
that you want the value to the nearest 1/16. The four indicates that you
want 4 decimal places in the result.
Public Sub TestRound()
MsgBox RoundToFractional(1.454667, 16, 4)
End Sub
' Variation of fractional converter function found at
' http://vbnet.mvps.org/index.html?code/helpers/numbertofraction.htm
Private Function RoundToFractional(ByVal DecimalNumber As Double, ByVal
LargestDenominator, ByVal DecimalPlaces As Integer) As String
Dim GCD As Long
Dim TopNumber As Long
Dim Remainder As Long
Dim WholeNumber As Long
Dim Numerator As Long
Dim Denominator As Long
WholeNumber = Fix(DecimalNumber)
Denominator = LargestDenominator
Numerator = Format(Denominator * Abs(DecimalNumber - WholeNumber), "0")
If Numerator Then
GCD = LargestDenominator
TopNumber = Numerator
Do
Remainder = (GCD Mod TopNumber)
GCD = TopNumber
TopNumber = Remainder
Loop Until Remainder = 0
Numerator = Numerator \ GCD
Denominator = Denominator \ GCD
RoundToFractional = Format(Numerator / Denominator, "0." &
String(DecimalPlaces, "0"))
Else
RoundToFractional = CStr(WholeNumber)
End Function
Brian Ekins
Autodesk Inventor API
"Laminator" wrote in message
news:5206052@discussion.autodesk.com...
Where do I put this code to accomplish the result
