Round decimal precision
M_Santi
M_Santi
So I'm trying to round the decimal places to 3 places of my custom Iproperties on my drawing.
I first created my parameters of the Area and Mass that I can manually type and not linked to any part model or assemblies.
Then I created a rule of having my custom Iproperties for area and mass to = the value of the parameters.
My main problem is that I can't set the decimal places to 3 places. I would be getting different kinds of decimal places? Is there a way for me to set the decimal places to only 3? I also want to remove the leading 0.
WCrihfield
Try this:
Wesley Crihfield
(Not an Autodesk Employee)
M_Santi
Are the parameters linked to a model because mine are not. I do not want my parameters to be linked to a model since I will be using the template with different models every time.
M_Santi
I found out how to do it myself, now I just need to find away to remove the leading zero.
This is the rule I used:
iProperties.Value("Custom", "Mass") = Round(MASS, 3)
WCrihfield
The images I posted were of the Parameters dialog within a part, so those parameters were for that part only, and not linked to any other model or Excel file.  However, if you want to use these values in a drawing, without pointing to any 'model', then you would have to do the same thing within the Parameters dialog of the drawing.  What this is doing is:  When you check the checkbox under 'Export Parameter' column, that automatically creates a matching custom iProperty that mirrors this parameter.  Then once that checkbox is checked, you can right-click on that row (for that parameter), and choose Custom Property Format, which will bring up that dialog, allowing you to customize the formatting and precision of the custom iProperty that it creates.  That custom iProperty will remain up-to-date to the parameter when it is created this way.
Wesley Crihfield
