Rotating Component in assembly around one of it's own axis
Daan_M
Message 1 of 8
Daan_M
Hi, I've got Component A in my assembly, which i want to rotate x degrees around it's own Y-Axis. I found the following which i think need
oCurrentOccurrence.Transformation.SetToRotation()
As input i need the the angle of rotation(variable), a workaxis(Y-axis of component), and a point (not sure what the point is for). I found a post of @WCrihfield describing i need to create a proxy to acces the components Work-Axis/Point so i did the following:
		Dim oCurrentOccurrence As ComponentOccurrence = oACD.Occurrences.Item(5)
		Dim oAngle = 90
		Dim oPoint As WorkPoint = oCurrentOccurrence.Definition.WorkPoints.Item(1)
		Dim oAxis As WorkAxis = oCurrentOccurrence.Definition.WorkAxes.Item(1)
		Dim oPointProxy As WorkPointProxy = Nothing
		Dim oAxisProxy As WorkAxisProxy = Nothing
		oCurrentOccurrence.CreateGeometryProxy(oPoint, oPointProxy)
		oCurrentOccurrence.CreateGeometryProxy(oAxis, oAxisProxy)
		oCurrentOccurrence.Transformation.SetToRotation(oAngle, oAxis, oPoint)
It throws an error on line 13
NOTES
  • Before this the component is placed in the assembly with '.AddUsingiMates' so this means there are contraints applied to the component. Once it is placed these contrains can be ignored.
  • To be clear, i need the component to rotate around it's own Y-Axis. NOT the Y-Axis of the assembly.
Replies (7)
Message 2 of 8
Andrii_Humeniuk
Hi @Daan_M . I see you're trying to use WorkAxis for the SetToRotation method, but you actually need to use Vector.
The line (13) that gives an error should look like this:
oCurrentOccurrence.Transformation.SetToRotation(oAngle, oAxisProxy.Line.Direction.AsVector(), oPointProxy)
I haven't tested it, but it seems you also need to use Point instead of WorkPoint.
oCurrentOccurrence.Transformation.SetToRotation(oAngle, oAxisProxy.Line.Direction.AsVector(), oPointProxy.Point)
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 8
Daan_M
Hi @Andrii_Humeniuk Thank you for the reply.
The code runs without error when i use your second suggestion:
Unfortunately I see no result, the component has not rotated in any way. Maybe the contrains from 'AddUsingiMates()' play a role?
Marked red = The component
Blue arrow = points to Y-Axis of the component
The updated code:
		Dim oAngle = 45
		MsgBox(oacd.Occurrences.Item(5).Name)
Message 4 of 8
Andrii_Humeniuk
If the constraint is in the plane of rotation then yes, you cannot rotate it, you need to suppress the constraint or delete it and create a new one in other planes.
Message 5 of 8
Daan_M
@Andrii_Humeniuk Ok i put in some code to delete the contraints, but the component still has not rotated.
Maybe i am doing something wrong defining the workpoint and workaxis. Right now i use '.WorkAxes.Item(1)' and '.Workpoints.Item(1) but i'm not even sure what (1) is. I want to rotate around the components Y-Axis and im not sure what the point is for. Are these things in the component by Default or do i need to define these placing them myself in the partfile as Axis and workpoint?
Updated code
		oACD.Occurrences.AddUsingiMates(oFullPath, False)
		'DELETE CONSTRAINTS
		For Each OCS In oCurrentOccurrence.Constraints
		OCS.Delete
		Next
		'ROTATION
		Dim oAngle = 45
Message 6 of 8
Andrii_Humeniuk
The Y-axis is numbered 2. The X-axis is numbered 1.
Message 7 of 8
Daan_M
@Andrii_Humeniuk Still no result
Made a clean test file, please see the attached Assembly and Partfile.
Run the code in the assembly called 'Rotate', i get no result in any direction.
Message 8 of 8
Andrii_Humeniuk
Try this:
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oACD As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence = oACD.Occurrences.Item(1)
Dim oAngle as Double = 3.14159265358979 / 4
Dim oPoint As WorkPoint = oOcc.Definition.WorkPoints("Work Point1")
Dim oAxis As WorkAxis = oOcc.Definition.WorkAxes("Work Axis1")
call oOcc.CreateGeometryProxy(oPoint, oPointProxy)
Call oOcc.CreateGeometryProxy(oAxis, oAxisProxy)
Dim oTransform As Matrix = oOcc.Transformation
Call oTransform.SetToRotation(oAngle, oAxisProxy.Line.Direction.AsVector(), oPointProxy.Point)
oOcc.Transformation = oTransform
If it does not move, try changing the degree.
Also keep in mind that the Inventor understands radians as degrees.
