Rotate Dxf File Geometry Using VBA Macro
isocam
isocam
Can anybody help?
Can anybody tell me if the following is possible?
I have a VBA macro that automatically outputs a dxf file of a 2d laser cut profile on any of the three Inventor work planes.
Two of the work planes outputs a dxf file in the same orientation as the sketch.
However, one of the planes outputs a dxf file that is rotated through 90 degrees.
Is there any way I can write a simple VBA macro to rotate the dxf files geometry through 90 degrees easily without having to do a set of geometry calculations to rotate each entity.
Is there a single line in a dxf file that I can change the rotation origin through 90 degrees???
Many thanks in advance!
Kind Regards
Darren
AndrewHumiston
morning,
could you send me a copy of the ilogic code you have. i have a  similar code but i have no issues with it rotating 90 degrees. but mine just flattens the sheet metal and does the dxf magic.,
