Rotate a Sketch Text on a Face in Assembly is not working
liminma8458
liminma8458
I am creating a sketch Text on a face in assembly, using the methodology from Xiaodong Liang in the article http://adndevblog.typepad.com/manufacturing/2016/09/create-sketch-text-on-face-of-assembly.html. This code works fine.
The problem is that I want to add rotation to the text and this rotation code does not work. I put the following code at the end:
oSketchText.Style.Rotation = 1.57
It is not working. "oSketchText.Rotation = 1.57" neither.
Actually, similar code works fine for sketch in drawing mode as i tested
Anyone can help?
Limin
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Limin,
There are 4 rotation option as below image and that should be defined in PI (3.14159265358979).
In VBA, 4 rotation can be achieved by following.
oSketchText.Rotation = 0 - 0 degrees
oSketchText.Rotation = 2 * Math.Atn(1) - 90 degrees
oSketchText.Rotation = 4 * Math.Atn(1) - 180 degrees
oSketchText.Rotation = 6 * Math.Atn(1) - 270 degrees
Please feel free to contact if there is any doubt.
If solves your problem, click on "Accept as solution" or give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
liminma8458
Hi, CHANDRA,
This solves my problem. Looks like it only accepts exact PI or PI equivalent expression, but not short digit number.
Thank you very much
Limin
