Ribbon customization - Pop-up button with more popup buttons inside
Jef_E
Jef_E
Is it possible to create a button structure like this?
I want a popup-up button like the image shows and then inside there are more popupbuttons that show multiple buttons.
Example as in the image
* Add Accessories
** Trunnion
*** Type 1
*** Type 2
** Nameplate
Thanks!
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Owner2229
I'm not sure about these 3-steps buttons, I guess I've seen it already somewhere so it shouldn't be a problem.
But first I'd look into other (more user friendly) options:
1) Place all your buttons in a form and reduce all the ribbon buttons to one (to open the form).
2) Use a combobox to select what you want to add (and add it immediately or after clicking another button).
If you have many item types:
3) Use search bar to look for what you want to add, filter the results into a combobox and re-use option 2)
4) Combine all of these into a form with search bar, maybe some tabs with categories.
I'm personally using the 4th option as I have thousands of part types to manage.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
