RevisonTable Add Function
I would like to create a macro that adds a revision table into the correct location on my sheet through vba.
I believe I have to use the following function, but I am having issues calling out the command:
Function Add(PlacementPoint As Point2d) As RevisionTable
Member of Inventor.RevisionTables
Creates a new RevisionTable object on the sheet
Can someone please show me some example code to show to add a revision table in this way?
The below VBA code can meet your request,
please try it.
Cheers,
Merry
VBA code:
Sub CreateRevTable()
    'This
assumes a drawing document is active
    Dim oDoc As
DrawingDocument
    Set oDoc =
ThisApplication.ActiveDocument
    Dim
oPt As Point2d
    Set oPt =
ThisApplication.TransientGeometry.CreatePoint2d(15, 15)
    Dim oRevTable As RevisionTable
    Set
oRevTable = oDoc.Sheets(1).RevisionTables.Add(oPt)
End
Sub
I
location on my sheet through vba. I believe I have to use the following
function, but I am having issues calling out the command: Function
Member of
sheet
Thanks Merry Jin. This is exactly what I wanted. It will help us update prints faster.
