Revision Table Dialog Box Control With iLogic
I would like to set the revision table to default as per the image below  using iLogic, but I would also like to disable the check boxes so they cannot be activated. Is this possible? I have tried the usual routes Google etc. and have checked the API programming help file but haven't been able to find the pertinent information (I can't see it for looking - if it indeed exists).
Thanks in advance for any help.
R.Mabery
Looking at the RevisionTable Obect, there is a boolean prop called UpdatePropertyToRevisionNumber.   I don't see anything for the Auto Index though.
Randy Mabery
Applications Expert
IMAGINiT Technologies
R.Mabery
Actually.....look at the Add2 Method for a RevisionTable.  It includes an argument for the AutoIndex argument.
Randy Mabery
Applications Expert
A.Acheson
The visibility of the option controls within that form are likely not exposed. You could call the command for revision box and with enable set to false remove it from the ribbon. This would mean a user cannot set the revision box options manually and ilogic is the primary method to call revision box creation/changes.
    'https://forums.autodesk.com/autodesk/attachments/autodesk/301/8282/1/INV2020_CommandNames_inclAddIns.txt
    Dim oCommandMgr As CommandManager
    oCommandMgr = ThisApplication.CommandManager
    Dim oControlDef As ControlDefinition
    oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingRevisionTableCmd")
    oControlDef.Enabled = True 'To remove Revision Box control from ribbon
Regards
Alan
Cheers Randy,
I will have a look at both your suggestions and see what I can do with them.
Cheers  A. Acheson
I will have a look at this and see what it does, unfortunately my skill levels are still at just basic iLogic level rather than API programming. I'll let you know how I get on.
Thanks again.
Hi Alan
So having had a look at your code, if I set it to False it disables the ability to insert the the revision table from the ribbon. This forces users to use the Vault revision table, but by default it seems to Auto-index and updates the revision number. That is not quite what I am looking to achieve, what I want is for the exact opposite. I will keep looking until I can find what I need, thank you for your help.
Paul.
