Revision Table Column width
Message 1 of 14
Hi everyone,
I've a problem setting the width of a column in a revision table inserted in a drawing via VBA.
Below my code
Sub RevisionTable()
    Dim oDrawDoc As DrawingDocument
    Dim oRTBs As RevisionTables
    Dim oLocation As Point2d
    Dim oRTB As RevisionTable
    Dim oRTC As RevisionTableColumn
    Set oDrawDoc = ThisApplication.ActiveDocument
    Set oRTBs = oDrawDoc.ActiveSheet.RevisionTables
    Set oLocation = ThisApplication.TransientGeometry.CreatePoint2d(30.253, 6.035)
    Set oRTB = oRTBs.Add(oLocation)
    oRTB.ShowTitle = False
    oRTB.TableDirection = kBottomUpDirection
    oRTB.RevisionTableColumns.Item(1).Delete
    oRTB.RevisionTableColumns.Item(3).Reposition (2)
    oRTB.RevisionTableColumns.Add (kRevisionTableSheetProperty)
    oRTB.RevisionTableColumns.Item(5).Title = "PROGETTISTA"
    oRTB.RevisionTableColumns.Item(5).Reposition (4)
    For Each oRTC In oRTB.RevisionTableColumns
      oWidth = "1.2"
      oRTC.Width = oWidth
    Next
End Sub
Can someone help me?
Thanks.
Replies (13)
Message 2 of 14
raymondxu
What is your inventor version?
Raymond Xu
Software Architect
Autodesk, Inc.
Message 3 of 14
JaneFan
Please change this line and have a try:
oWidth = 1.2
Jane Fan
Inventor/Fusion QA Engineer
Message 4 of 14
raymondxu
Your VBA code can work well on my Inventor 2017. Please let me know your version, I will see whether we have a defect there.
Thanks!
Ray
Raymond Xu
Software Architect
Autodesk, Inc.
Message 5 of 14
thanks for your reply!
I've tried with 1.2 but same problem...
Message 6 of 14
thanks for the reply.
I've a 2016 Inventor version 64 bit.
Message 7 of 14
The Same code is working fine in Inventor 2016 also except the column number 5, because in my revision table I set only 4 columns. please check the name of column 5 and try.
Message 8 of 14
I've tried disabling the formatting to column 5 but...same error (see below)
The debug points to the line with the 'Width' method.
Message 9 of 14
Snivek
Try oWidth = 1.2 in
Message 10 of 14
Snivek
Nevermind. Here is what I did to get it to work in iLogic.
Dim oLocation As Point2D
oLocation = ThisApplication.TransientGeometry.CreatePoint2d(30.253,6.035)
oRTB.TableDirection = TableDirectionEnum.kBottomUpDirection
oRTB.RevisionTableColumns.Item(3).Reposition(2)
oRTB.RevisionTableColumns.Add(RevisionTablePropertyEnum.kRevisionTableSheetProperty)
oRTB.RevisionTableColumns.Item(5).Reposition(4)
oRTC.Width = 1.2
Next
Message 11 of 14
Message 12 of 14
tried with iLogic...please see the following error reported.
Thanks.
Message 13 of 14
JaneFan
I tried with Inventor 2016 but the code can be run without error both via VBA and iLogic.
Not sure what kind of settings of the document is making the trouble.
Would you please try to create a fresh drawing document, and do nothing but run your code via VBA or iLogic to see whether there is still error to set Width?
Jane Fan
Message 14 of 14
Ciao,
I tried with a fresh drawing but...same problem...
Actually I'm a litlle bit confused...I can not understand what is different my Inventor from yours.
Thanks.
