Rev Table Location
Rev Table Location
Rev Table Location
I am currently setting up templates for our company to use and would like to set a default location for the revision table to be as we always want it to be at the left side of the title block.  I don't want to just place it there in the template as it should only display if there is a revision for that drawing.
I haven't been able to find a setting that will do this so am thinking about a macro that will automatically run when "Revision Table" is clicked.  If this is indeed the best option, I will need some guidance in what to code as I have had VBA experience in Excel but very little with Inventor.
Any ideas?
Thanks!
You will need to get the TitleBlock RangeBox... something like this
Dim oSheet As Sheet = thisapplication.ActiveDocument.ActiveSheet
Dim oTB As TitleBlock = oSheet.TitleBlock
Dim FinalPoint As Point2d = FriendInventor.TransientGeometry.CreatePoint2d(0, 0)
Then you will need to set a reference to your RevBlock, and subtract its MinPoint.X from its MaxPoint.X and then subtract that from the X below.   The Y should be at the same Y as the Titleblock Y I would guess.
FinalPoint.X = oTB.RangeBox.MinPoint.X
FinalPoint.Y = oTB.RangeBox.MaxPoint.Y
But you will most likely need to make your own button and make your own code to add the RevBlock.  I don't know of any way to tag code onto a existing button press.
I am now trying to move the revision block once it is already been created (for when the sheet size changes).
I have tried using the following code and it appears that all the values are correct but the assignment doesn't work.
    oSheet.RevisionTables.Item(1).Position.X = pFinalPoint.X
    oSheet.RevisionTables.Item(1).Position.Y = pFinalPoint.Y
Any ideas?
Figured it out.  I used this instead:
oSheet.RevisionTables.Item(1).Position = pFinalPoint
