Retrieve Dimension from Assembly - Slow
johnster100
johnster100
I'm using the code from here:
https://adndevblog.typepad.com/manufacturing/2016/03/retrieve-sketch-dimension-of-part-document-insi...
to retrieve dimensions from an assembly. The issue is when i use it on a large assembly it's incredibly slow (can take up to 5 minutes) or sometimes Inventor just freezes indefinitely.
i can check that dimensions are retrieveable by using:
oSheet.DrawingDimensions.GeneralDimensions.GetRetrievableDimensions(oView, oDCproxy)
and this line executes very quickly. But when i come to retrieve the dimension Inventor freezes
My assembly I'm retrieving from has lots of parts with derived sketches, so I'm wondering if it's something to do with that?
Is there another method i could try?
Any help would be appreciated,
thanks,
John
WCrihfield
Are you trying to retrieve all retrievable dimensions from the model in the view, or just specific ones, or only from specific sub-assemblies/parts within the assembly shown in the view?  Are you trying to retrieve dimensions into every view within your drawing document with one run of the rule, or just one view per rule run?
If all views in your drawing are of the same main assembly, you can bypass getting the assembly document for each oView.ReferencedDocumentDescriptor.ReferencedDocument, and simply use ThisDrawing.ModelDocument near the top one time.
Wesley Crihfield
(Not an Autodesk Employee)
johnster100
i'm just trying to get one dimension. It's from a sketch that's shared to several other parts however, I think this is where the problem comes.
From the one dimension constraint the GetRetrieveableDimension function returns a count of 27 dimensions. This will be due to the sketch being shared and some parts are patterened.
I've also tried retrieving all the dimensions for the specific occurrence but this causes inventor to crash.
thanks,
John
WCrihfield
I haven't tried it yet myself, but I wonder if this method would work, instead of using the GetRetrievableDimensions() route?
oView.SetIncludeStatus(oObj, True)
oView.SetVisibility(oObj, True)
(Where oObj is the dimension you're trying to show in your drawing)
Wesley Crihfield
johnster100
I couldn't get that to work.
Is there anyone at autodesk who i could send my files to for their opinion? (i'm not allowed to upload them to a public forum).
thanks,
John
