Resort components order in assembly BOM
aries.1482
aries.1482
I have a main-assembly with a sub-assembly and parts. In main-assembly BOM, I want to show all components in sub-assembly so I choose All Levels in Structured Properties. It's OK. But the issue is the order of those components in main-assembly BOm is not the same in sub-assembly BOM. For example:
Sub-assembly: SubPart 1 as Item 1, SubPart 2 as Item 2
Main-assembly: SubPart 1 as Item 1.2; SubPart 2 as Item 1.1
(see attach below)
Is there any code to resort all components in main-assembly BOM so they have the same order in sub-assembly BOM?
Plz help me. Thank you.
JohnKHouston
Try using the 'Sort By' option. It's the button up at the top with the A->Z icon. It should allow you to sort by any column that you have in your BOM. No code required...  🙂
aries.1482
Thanks for reply.
I know option "Sort by", but part number is not like in the example, it is random character so I can't sort by part number.
JohnKHouston
Gotcha, I was too literal because of your example. Good luck, hope you find a solution!
Ralf_Krieg
Hello
There's AFAIK no way to move the BOM rows.
You can try to copy the item numbers from subassembly BOM to main assembly BOM and order by item number. This should "reorder" the BOM rows in main assembly BOM. After this you should renumber the main assembly.
Below is a VBA example. Don't know if it works 100%.
Option Explicit
Private Sub BOMReorder()
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oAssDoc As AssemblyDocument
Set oAssDoc = oApp.ActiveDocument
Dim oBOM As BOM
Set oBOM = oAssDoc.ComponentDefinition.BOM
If oBOM.StructuredViewEnabled = False Then Exit Sub
If oBOM.StructuredViewFirstLevelOnly = True Then Exit Sub
Dim oBOMView As BOMView
Set oBOMView = oBOM.BOMViews(2)
Dim oBOMRows As BOMRowsEnumerator
Set oBOMRows = oBOMView.BOMRows
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMRows
    If Not oBOMRow.ChildRows Is Nothing Then
        Call TraverseBOM(oBOM, oBOMRow)
Next
Call oBOMView.Sort("Item")
Call oBOMView.Renumber
End Sub
Private Sub TraverseBOM(ByRef oBOM As BOM, ByRef oBOMRow As BOMRow)
Dim oRefedDoc As AssemblyDocument
Set oRefedDoc = oBOMRow.ComponentDefinitions(1).Document
Dim oSubBOM As BOM
Set oSubBOM = oRefedDoc.ComponentDefinition.BOM
oSubBOM.StructuredViewEnabled = True
oSubBOM.StructuredViewFirstLevelOnly = False
Dim oSubBOMView As BOMView
Set oSubBOMView = oSubBOM.BOMViews(2)
Set oBOMRows = oBOMRow.ChildRows
Dim oChildRow As BOMRow
Dim oSubChildRow As BOMRow
Dim i As Integer
For Each oChildRow In oBOMRows
    For i = 1 To oSubBOMView.BOMRows.Count
        If oSubBOMView.BOMRows(i).ReferencedFileDescriptor.FullFileName = oChildRow.ReferencedFileDescriptor.FullFileName Then
            oChildRow.ItemNumber = oSubBOMView.BOMRows(i).ItemNumber
    Next
    If Not oChildRow.ChildRows Is Nothing Then
        Call TraverseBOM(oBOM, oChildRow)
Next
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
aries.1482
Thank you, I'll try this.
