Resolution, some images and icons too small to see
Kerry.McInnes
Kerry.McInnes
I'm having some type of resolution issue or something. That's  why I'm here, maybe you guys can help me out. I'm running Inventor 2020 in bootcamp on an imac. I've done this for quite awhile (since 2011) and it works great, but for some reason or another some images are coming up extremely small. On startup you can see how small the window is and the main problem I'm having is the "little green dot" node is extremely small. all of my other icons are normal and so is my other Autodesk software bit for some reason I cannot get Inventor to cooperate no matter what I do. I've played with screen zoom and resolution and still no luck, they're consistently proportionately smaller. Any help would be greatly appreciated
WCrihfield
That's pretty odd.  Sounds like some sort of Windows glitch, or perhaps some sort of obscure Video Card/display adapter settings messed up.  However, I'm not the expert system troubleshooter, so here are a few Autodesk links, just in case it is something on Inventor's side.
Regular Inventor Forum
Inventor Troubleshooting
Wesley Crihfield
(Not an Autodesk Employee)
