I found a small bug in an addin I developed for Inventor. I have buttons on the ribbon specific for the drawing environment that switch the size of the drawing sheet. If the user reaches the A4 paper, the downsize button is disabled and vice versa when reaching paper A0. That works all fine, except when the user switches between different drawing documents. Inventor "remembers" the button settings from the previous file. So when in document 1 the paper size is A4, the size down button is disabled. If you then switch to document 2, the button will still be disabled, even if the paper size is not A4.
So what I am looking for is a way to 'reset' the ribbon when switching between documents. As it is now, the disable ribbon buttons is done On Document Change.
