req: small macro to save idw
Message 1 of 11
Our numbering in the company for moddels is a 10 digit number followed by -M1 for parts as for assy.
When we save a drawing this will become automaticlly the 10 digit number with -M1. We always need to change the M1 to 01.
Can someone write me a code with replaces the M with a 0 and then saves it automaticlly?
so for instance you make a drawing you put on a view of a part or an assy with a number like 1624254800-M1 you start the macro and it wil save it as 1624254800-01.idw
thx in advance!
Stefaan
Replies (10)
Message 2 of 11
"Can someone write me a code ... "
How much are you paying?
Message 3 of 11
how about a thx on my site? That's all I can offer...
I don't thinck the code will be that long no? Message was edited by: Stefaan Boel
Message 4 of 11
I only made the comment in jest.
If I can help I will, but I don't have a ready solution at the moment.
I did find these that may help -
http://discussion.autodesk.com/thread.jspa?messageID=1080291
http://www.mcadforums.com/forums/viewtopic.php?t=3857&highlight=rename+idw+file
Maybe there's someone else out there...
Message 5 of 11
you`re in luck
i have just finished something similar a couple of days ago
here ya go
Public Sub saveas()
Dim oApp As Application
Dim oCurrentDoc As Document
Set oApp = ThisApplication
Set oCurrentDoc = oApp.ActiveDocument
sPartFileName = oCurrentDoc.ReferencedFiles(1).DisplayName
Dim words() As String
Dim Delimiter As String
Delimiter = "-"
' Split the string at the "-" characters.
words() = Split(sPartFileName, Delimiter)
sM1 = Left(words(1), 2)
Dim spath As String
spath = "C:\"
If sM1 = "M1" Then
oApp.SilentOperation = True
Call oCurrentDoc.saveas(spath & words(0) & "-" & "01" & ".idw", False)
End Sub
That would be 100$ payed by the end of the millenium
:) Message was edited by: cozmin
Message 6 of 11
Hello Cozmin,
thx a lot, this works perfectlly!!!
by the way, if i'm still alive by then and Inventor still excists i'll pay you that $100, just remind me 🙂
until next time!
Stefaan
Message 7 of 11
I wanted to add some extra code, so when you click on it again you just do a normal save since the file already excists (that's what he's checking)
Public Sub saveas01()
Set fs = CreateObject("Scripting.FileSystemObject")
sFileName = oCurrentDoc.DisplayName
Dim spath As String
spath = "C:\Working_Dir_Smarteam\"
If fs.FileExists(spath & sFileName) Then
Call oCurrentDoc.Save
Else
Delimiter = "-"
If sM1 = "M1" Then
End Sub
Message 8 of 11
you have to redo all the words() stuff
delimitedstring= ocurentdoc.name
if sM1 = "01" Then
end if
if this is what you want
Message 9 of 11
So, this is what i'm having now.
I changed this line to displayname
Delimitedstring = oCurrentDoc.DisplayName
But now the strange thing is when I click it it does the save to the idw, click again it does a save.
Next time I click it debugs!?! I end it, click it again and it saves.
Again seconde time debugs.
why?
Public Sub saveas02()
Dim spath As String
Dim wordsdoc() As String
Dim wordslink() As String
'Link filename and referenced file name to parameter
Delimiter = "-"
wordsdoc() = Split(Delimitedstring, Delimiter)
s01 = Left(wordsdoc(1), 2)
wordslink() = Split(sPartFileName, Delimiter)
sM1 = Left(wordslink(1), 2)
'Do a doc save
If s01 = "01" Then
Else
If sM1 = "M1" Then
Call oCurrentDoc.saveas(spath & wordslink(0) & "-" & "01" & ".idw", False)
End Sub
Message 10 of 11
perhaps there is a save watch
if the doc is saved then it doesnt perform onether save until you change something in the doc (just a guess)
pu this statement the first line after the
On Error Resume Next
and it will skip the error
Message 11 of 11
Life can be so easy!
I thank you a lot for helping me out until I got it right!
