Replace Sub assembly in Main assembly with iLogic
Pratik.Ksoni
Pratik.Ksoni
i am using Inventor iLogic and good familiar with this, does any one guide me that how to replace sub assemblies into main assembly since i am aware at part level only.
Pratik
JaneFan
Hello Pratic,
Please try this line with replacing the occurrence name and assembly file name you want to replace with.
SyntaxEditor Code Snippet
Component.Replace("SubAssembly:1", "OtherAssembly.iam<Master>", True)
Jane Fan
Inventor/Fusion QA Engineer
Pratik.Ksoni
 Hello Jane,
i am sorry for late response, i tried given Syntax but it is not works since i need to replace iassemblies.
it will be highly appreciate if you provide me with actual example.
Pratik
t_hascj
Hi Pratik,
I'm not sure if it is helpful for you, but in iParts snippets are some helpful hints. The iLogic object iPart works also for iAssembly.
Jaroslav
