Replace Styles and Standards in a drawing using iLogic
MSt-Louis
MSt-Louis
I'm looking for a solution which is to replace all styles and standards in a drawing like Dimensions Styles, Layers Styles etc... by new ones. Using iLogic.
The idea is to use an old drawing that was made for an old customer and run a code that will 'REPLACE' all the old styles with new styles that will meet the new customer's requirements.
I know they are few posts on that subject but I don't like the solutions proposed. Specifically when it comes to replace Dimension Styles. The codes I found, always browse in a drawing sheet and gets all the dimensions in it and changes individually the actual style by a new one. But if you do so, you loose all modifications made to a specific dimension. E.g. changes made on the amount of digits.
What I'm looking is a code that will go in the Style Manager and literally REPLACE a style by another style. As it is possible to do manually.
Is this available in Inventor API?
Thanks.
theo.bot
when you access the drawingstylesmanager you can use replacestyles it available since inventor R2021.
Inventor 2022 Help | DrawingStylesManager.ReplaceStyles Method | Autodesk
here is a sample rule to update styles from a template. By replacing the object defaults style, it will update all object in the drawing where the style is set "by standard".
MSt-Louis
Thank you theo.bot for you explanations. The are very useful.
I think you understood exactly what I was looking for. But I am using R2019 so I don’t have access to ReplaceStyles Method. No wonder why I couldn't find it.
Fortunately, my IT told me that we would get R2021 somewhere in March 2022. I'll be able to test the code you provided at that time. I'll keep you in touch.
Once again, thank you.
KB6AWRA
Hello, did this solution work? Or is it possible to do so without using iLogic?
